Post by vikx on Jul 2, 2013 23:21:41 GMT -8
Anybody heard of it?
machinelf
1971 Model 1400 named Harriet
Post by machinelf on Jul 3, 2013 4:59:56 GMT -8
Oh yes. Did you make one and live to tell about it?
Post by bigbill on Jul 3, 2013 5:19:47 GMT -8
Did you serve it on a hot grand as suggested? Did you die afterward?
Post by Nomad on Jul 3, 2013 6:30:35 GMT -8
boandsusan
Post by boandsusan on Jul 3, 2013 7:32:13 GMT -8
OMG lol. I`m gonna try that this weekend.....I don`t think this would kill you if you only ate it once a year or so.
Post by bigbill on Jul 3, 2013 10:17:24 GMT -8
Yes you guys are right about it killing you , BUT what a way to go they probably couldn't get the smile or the sauce off your face. Anyway better that than second hand smoke
Post by Hamlet on Jul 3, 2013 17:12:40 GMT -8
We ordered that at a restaurant once. It came with a coupon for a cardiology consult.
Post by Ten on Jul 3, 2013 17:25:09 GMT -8
I am assuming the "explosion" part refers to your heart about two hours after consumption. At least the name of the recipe gives a little warning...
Post by vikx on Jul 3, 2013 22:30:24 GMT -8
Recipe here, please...
Post by bigbill on Jul 4, 2013 2:55:58 GMT -8
Bacon Explosion by Boss Hog Click for Bacon!
You want the Bacon Explosion? We’ve got your Bacon Explosion right here!
What you’ll need: 2 pounds thick cut bacon 2 pounds Italian sausage 1 jar of your favorite barbeque sauce 1 jar of your favorite barbeque rub
To begin construction, you’ll need to create a 5×5 bacon weave. If the strips you’re using aren’t as wide as the ones pictured, then you may need to use a few extra slices to fill out the pattern. Just make sure your bacon weave is tight and that you end up with a nice square shape to work with. The next step is to add some barbeque rub on top of your bacon weave. Use your favorite rub/seasoning for the ultimate explosion. Now that your bacon is well seasoned, it’s time to add the sausage. Take two pounds of Italian sausage and layer it directly on top of your bacon weave. Be sure to press the sausage to the outer edges of the bacon creating a patty that is the same thickness all the way across. Most grocery stores carry loose sausage, so just pick whichever you prefer. If you like it spicy, make it spicy.
Next up is bacon layer number two. Take the remaining bacon slices and fry them up to your liking (crunchy, crisp, chewy- what have you). Regardless of how well done you like yours, you’ll need to crumble or chop the cooked strips into bite size pieces and place on top of the sausage layer. Since this is a barbeque recipe, you need to add another layer of barbeque flavor. Take your favorite sauce and drizzle it all over the top of the bacon pieces. Once you’ve sauced the bacon, sprinkle on some more of the barbeque seasoning you used on the bacon weave.
After you have finished saucing and seasoning the pork-tastic creation, you have to roll it. Carefully separate the front edge of the sausage layer from the bacon weave and begin rolling it backwards. You want to include all layers except the bacon weave in your roll. Try and keep the sausage as tight as possible and be sure to release any air pockets that may have formed. Once the sausage is fully rolled up, pinch together the seams and ends to seal all of the bacon goodness inside.
At this point we can start to see the final shape of your Bacon Explosion, but we’re missing one key item. To complete the construction process, roll the sausage forward completely wrapping it in the bacon weave. Make sure it sits with the seam facing downward to help keep it all sealed up.
Sprinkle some barbeque seasoning on the outside of the bacon weave and now it’s ready to be cooked up. Cook your Bacon Explosion at 225 degrees in a constant cloud of hickory smoke until your gives an internal temperature reading of 165 degrees. Normally this will take about 1 hour for each inch of thickness, but that could vary depending on how well you maintain your fire and also how many times you open the smoker to take a peek.
Now that your Bacon Explosion is fully cooked, you need to add some finishing flavors. Using a basting brush, coat the entire surface of the log with the same barbecue sauce you had used earlier. Make a thin layer. Sweet sauces are loaded with sugars, so they’ll give your fatty a nice glossy finish. Spicy and vinegar based sauces don’t contain as much, so they won’t set up as well. If you’re dead set on using those sauces, just cut them with a bit of honey and you’ll get the same effect.
Slice the Bacon Explosion into quarter to half inch rounds to serve. If your roll was good and tight, you should now see a nice bacon pinwheel pattern throughout the sausage. Obviously pork is best served by itself, but if you feel the need to make this meat monster into a sandwich, try placing a couple Bacon Explosion slices on your favorite sandwich bread.
Post by bigbill on Jul 4, 2013 3:16:27 GMT -8
Other recipes call for serving it on a pillsbury grand biscuit instead of bread.
hoosierpoet
Post by hoosierpoet on Jul 4, 2013 4:26:58 GMT -8
Wonder if you could substitute turkey bacon and chicken sausage - then you could eat it every day, right? Maybe a little tofu-something-or-other on the side...?
Post by bigbill on Jul 4, 2013 7:46:56 GMT -8
I'm sure you could but it wouldn't be the same without all the fat. Anyway you can't live forever.
Post by Ten on Jul 4, 2013 7:59:51 GMT -8
I'm sure you could but it wouldn't be the same without all the fat. Anyway you can't live forever. If something is going to take you out anyway, it may just as well be bacon!
Post by bigbill on Jul 4, 2013 8:10:48 GMT -8
Hey and the only way to go better than bacon would be bacon and sausage together. Think we should forward this to our doctors?
