boandsusan
Post by boandsusan on Jun 30, 2013 14:07:44 GMT -8
The heads on the tacks used in the above picture are TOO big but it was about to storm and these are what came out so we reused them. Plus because of the damaged to the edging on these corners (po opening and closing them) I did use some thin black butyl tape between the metals.
boandsusan
Post by boandsusan on Jun 30, 2013 14:09:31 GMT -8
Thanks for all the pictures!! It looks like you are finding the same rot that I am. Wow, I bet that AC unit in the front let in some water!!!! Jeff It was BAD. Stick around and you`ll see how we installed an under the bed AC in this one.
boandsusan
Post by boandsusan on Jun 30, 2013 14:11:24 GMT -8
New wiring and all new insulation went in walls and ceiling.
boandsusan
Post by boandsusan on Jun 30, 2013 14:14:28 GMT -8
Now for the Birch I figured 13 sheets of 1/4 inch Birch for the interior (including wardrobe, benches and new kitchen facinc etc). I shellacked on a plastic covered pool table inside the house as I wanted it to dry in the AC . This is, one sheet raw, 1 sheet with one coat and one sheet with 3 coats Sanded lightly with sand paper between each coat. We decided on 3 coats but had the interior been larger, we would go with 4-5 coats of amber shellac.
boandsusan
Post by boandsusan on Jun 30, 2013 14:20:10 GMT -8
YES this Shasta does have a rear window.....I hadn`t cut it out when I took the above picture.
boandsusan
Post by boandsusan on Jun 30, 2013 14:23:15 GMT -8
I used flat screen trim where the sheets butted up across the ceiling.
boandsusan
Post by boandsusan on Jun 30, 2013 14:25:43 GMT -8
Close up of the trim screws that I chose to use. I really like these little buttons as they dress the birch up without being too flashy.
boandsusan
Post by boandsusan on Jun 30, 2013 14:28:24 GMT -8
I used 1/4 round (wood) on the corner seams. A 20 degree cut on the Horizontal flat trim where it butts upto the 1/4 round.
boandsusan
Post by boandsusan on Jun 30, 2013 14:30:56 GMT -8
We decided on the wavy overhead cabinet up front.
boandsusan
Post by boandsusan on Jun 30, 2013 14:34:47 GMT -8
At this point Bo finished up the wiring for me . Oh and I used the jigsaw at top speed using a super fine blade for the wavy cut out. I found that it cut a lot neater if I cut it with the face side up.
boandsusan
Post by boandsusan on Jun 30, 2013 14:37:23 GMT -8
Next was the 3/4 bed and new kitchen framing.
