vschwartz0001
1959 Oasis 17-6
Post by vschwartz0001 on Jun 14, 2014 10:26:22 GMT -8
I have 1 1/2 inch walls. When I insulate with the green foam should I leave some kind of air gap or should I fill the cavity all the way Thanks Adam
Sent from my SAMSUNG-SGH-I847 using Tapatalk 2
Air gap
Jun 16, 2014 21:18:36 GMT -8
Post by vikx on Jun 16, 2014 21:18:36 GMT -8
When I insulate with foam, I fill the cavity and use the foam as a vapor barrier as well... Pushed into each framing area, it stays tight and secure.
Post by soup on Jun 17, 2014 3:25:58 GMT -8
I also use 3M Cold Weather aluminum tape to seal the insulation to the frame sticks to create the final total vapor barrier seal. Not cheap though at $15 a roll!
Air gap
Jun 17, 2014 6:09:21 GMT -8
Post by SusieQ on Jun 17, 2014 6:09:21 GMT -8
I spent almost as much on foil tape as I did on the insulation. Of course, I pulled some out and retaped for various reasons (like adding wiring after I thought I was finished wiring). Sadly, I've grown quite accustomed to the smell of voil tape.
