wiartonwillie
1953 McGuinness Silver Duke
Post by wiartonwillie on Jun 11, 2014 15:50:44 GMT -8
I just found a 1964 Shasta that is located only 2 miles from my house. The owner wants to sell it. It has been sitting for a number of years, and I may go look at it this weekend. Where is the most common place that the Shastas rot.
Post by schweetcruisers on Jun 11, 2014 15:56:56 GMT -8
The question should be, where don't they rot, that answer is shorter!
Post by Ten on Jun 11, 2014 16:22:19 GMT -8
A '64 Shasta any model should be the canned ham shape. The water will run along the curves to the bottom, and the worst of the rot will generally be at the base of the 4 corners. Around the door frame and wheel wells, the skirt boards will need close inspection.
Of course if it has sat uncovered and unattended for years the tape along the whole seams would be suspect, and the seepage can show up in the corners of the ceiling and wall, especially in the rear above the bunk. Beneath the windows, rear window and especially the side fixed windows over the dinette seats will also be bad spots, generally speaking.
Schweet really did hit the nail on the head. Rot will be easy enough to detect. The real "hunt" would be for typically rotten spots that are not. The more of these you find the faster you should tow it home and ask questions later.
Post by universalexports on Jun 11, 2014 16:37:52 GMT -8
common places are under the front side windows, under the rear window and around the vent in the roof, also check under the water tank.
wiartonwillie
Post by wiartonwillie on Jun 11, 2014 16:57:49 GMT -8
I don't even need another trailer, but I thought that if it was fixable I would pass the info on to this everyone here. Is there any parts that are hard to find that I should look for. I may get it and sell it for parts.
Post by schweetcruisers on Jun 11, 2014 17:15:26 GMT -8
The gas light
Post by Ten on Jun 11, 2014 17:37:14 GMT -8
A working propane refrigerator.
If you decide that parting it is the way to go, I am still looking for a complete rear window assembly...the push-out type.
yas
'63 Shasta Airflyte
Post by yas on Jun 11, 2014 18:52:04 GMT -8
Bargman L-66 door lock assembly is worth $
Post by Hamlet on Jun 11, 2014 19:14:19 GMT -8
What model is it?
Post by soup on Jun 12, 2014 0:56:50 GMT -8
I just found a 1964 Shasta that is located only 2 miles from my house. The owner wants to sell it. It has been sitting for a number of years, and I may go look at it this weekend. Where is the most common place that the Shastas rot. Front & back wall corners (All 4 corners), roof vent, ceiling to wall corners, under front and back windows, floors, you name it! LOL
wiartonwillie
Post by wiartonwillie on Jun 12, 2014 15:09:03 GMT -8
How do you tell what the model is? Any markings on the outside? I will get some pics of the door lock, rear window and any gas lights.
Post by Ten on Jun 12, 2014 17:16:09 GMT -8
The earlier 60's models were not labeled, as in did not have model names posted on the trailer anywhere. There are some identifying features that make identifying easy enough, if you know what to look for. We'll be glad to help ID with some photos and description...:-) .
Post by mobiltec on Jun 14, 2014 8:44:22 GMT -8
By 64 they had fixed the solid side dinette window problems by eliminating the solid side front dinette windows. However even the Jalousies will leak if they are not pulled and resealed in time. Because of demand, I wouldn't part out ANY Shasta now. Even if it's falling apart just sitting there it's a valuable item.
wiartonwillie
Post by wiartonwillie on Jun 14, 2014 16:40:51 GMT -8
imgur.com/a/KcQu2Hey everyone here is the Shasta that I am trying to get. The owner said it is a 64, does anybody know the model. Let me know what you think.
yas
'63 Shasta Airflyte
Post by yas on Jun 14, 2014 16:52:06 GMT -8
A couple of things that would make ID more positive - the length and if it has a bathroom.
Assuming no bathroom, I'm going to say it's an Airflyte. 16' long (13' body).
