kc
1959 Shasta
Post by kc on May 25, 2014 21:26:04 GMT -8
Working on exterior. For paint eventually but will be bare aluminum for awhile..removed most via stripper but would like to sand/polish until I get around to painting. Recommend particular brand? Or just harbor freight? Any advice on best grit to begin with and steps to get best results?
Post by John Palmer on May 25, 2014 21:59:22 GMT -8
You will need "lots of CFM volume" to run a DA.
The cheaper DA's work OK, if you have enough air volume.
You want enough CFM volume so the compressor is able to keep up, and not over heat by running constantly. IMO, a 220V compressor is about minimum to do any body work, or spray painting.
Post by vikx on May 25, 2014 22:10:32 GMT -8
Depends on the skin condition. It you won't be repairing dents, a Scotch scruff pad might even the surface. We do that or sand with 220, then 320, then prime. Sand again with 400/600 and paint...
Since you won't be painting right away, I would use aluminum wheel cleaner and a scruff pad to get a mill finish. You can always keep going if you're not happy with the result.
Polishing is another world away. Lots of elbow grease, black debris that sticks to you, spendy rouge and fancy machines...
kc
1959 Shasta
Post by kc on May 26, 2014 6:52:29 GMT -8
What about electric?
Post by bigbill on May 26, 2014 18:47:49 GMT -8
HF sell an electric DA that is great for polishing and buffing, I don't know why it wouldn't work for sanding it is around $50.00 depending on coupons and sales.
bmxovich
1952 Airfloat Skipper
Post by bmxovich on May 28, 2014 4:11:09 GMT -8
You might look at Porter Cable. I have an elec random orbital of theirs that works very well, and I've used it a TON. It's over 10 years old and has been flawless. The issue with it and especially the new version of it is weight. Mine weighs double what an air version does, and the new one is awfully heavy. If you have even a hint of tendinitis issues, I'd stay away from them. But, they do make a small compact version that more closely resembles a DA. That might be the ticket.
