houdini
Post by houdini on May 21, 2014 12:16:30 GMT -8
Our dometic refer seems to only work with 12volt power. Is there some type of switch I need to flip so it will work on 110. I am really confused on this. Thanks H
Post by vikx on May 21, 2014 22:06:29 GMT -8
If it's working, the cooling unit is still OK. None of us know for how long...
Sounds like your 110 element is burned out. Do some research on the model and see if a replacement is available.
houdini
Post by houdini on Jun 18, 2014 19:03:54 GMT -8
If it's working, the cooling unit is still OK. None of us know for how long... Sounds like your 110 element is burned out. Do some research on the model and see if a replacement is available. Found the issue with the refer. The plug was loose. Just plugged her in and wall! I feel like a Dork for not checking that first...
Post by vikx on Jun 18, 2014 20:33:10 GMT -8
Snicker...
