Flat-Tire
1965 Da-Vid
Post by Flat-Tire on Mar 28, 2014 17:53:15 GMT -8
I'm using only one tank. For a 1965 two burner stovetop, what PSI regulator do I look for? I think I need 1/2 PSI.
Do I need a two stage regulator?
Thanks
Post by vikx on Mar 28, 2014 22:03:47 GMT -8
You will need an RV regulator, at 11 inches water column. (they are factory set) A two stage regulator is required nowadays.
Don't confuse the single two stage regulator with a dual auto changeover regulator. The dual regulator is used with two tanks.
An RV shop should be able to sell you a two stage regulator in the configuration you need. Some are sideways, others upright, etc. It depends where the vent is located how they are mounted.
Hope this helps.
