CorvettCrzy
'58 Corvette, '64 Franklin
Post by CorvettCrzy on Jan 11, 2017 16:41:43 GMT -8
Thank You Redwings! I wanted to post a pic of my finished awning here because when I was reading through the tutorial I wished there were more pics to look at. I followed most of the tutorial, only slight variations. Awning1 by Corvett crzy, on Flickr
Post by vikx on Jan 11, 2017 22:46:35 GMT -8
WOW! I love the colors....
Post by mel on Jan 12, 2017 15:42:47 GMT -8
I am considering making an awning out of laminated fabric which is where one side is waterproof, sorta looks shiny like a raincoat or something. Does anyone have any opinions about how that might hold up?
Post by vikx on Jan 12, 2017 22:37:50 GMT -8
Mel,
Find out if the fabric is UV resistant. That will tell you if it will last. I'm guessing the plastic is not UV resistant but you might be able to coat it with something.
CorvettCrzy
Post by CorvettCrzy on Jan 14, 2017 19:04:32 GMT -8
Mel Besides the UV rating, one other thing to consider is the needle marks. If you were to make an error and had to tear it out, the needle holes might show. Also tension over time may "stretch" the plastic also creating larger holes. Just thinking out loud. I'm not that familiar with that type of fabric, I've seen it but never worked with it. You might want to stop at a quilt shop and ask a few questions. I love my fabric and although it's most likely not "awning" fabric, it is a Poly Solarium so I feel it should be UV resistant. I may decide to use a waterproofing spray, my husband uses it on our boat cover every year and it seems to work well. But I'll definitely test it first. I spent some time on the website Redwings suggested fabricguru.com they had a pretty good selection of outdoor fabric and if you get seconds, it's not as costly. My fabric was seconds. I had a budget, spent a little more than I initially planned but I fell in love with it. The first picture below is the back side, you can see that it appears they didn't have enough die on the black stripe to the LH of the orange. You'll also notice that some of the other stripes don't appear to be "solid". Solarium Seconds by Corvett crzy, on Flickr Here is a picture of the same piece, right side of the fabric. You can see the defect is a light area within the stripe. It's not all the way through the bolt, just in some areas and only that particular stripe. For me this acceptable since it is the top of the awning and I got the fabric at a ridiculous price because of it (about $6 a yard). Also my fabric is very colorful which probably helps distract the eye from the actual defect. It was written up in the description as off register. I did find one other spot where a stripe was and a sliver of white showed, but I couldn't even find it to take a picture. When I bought it a couple years ago they had several pieces, different lengths, with different defect descriptions. I also purchased marine vinyl for my gaucho at about $10 a yard. I purchased samples ($1 each) prior to deciding and was glad I did, however, the sample didn't show the defect. You'd want to check but I believe you can return the order as long as you don't cut it. But you might have to pay for the return shipping so keep that in mind. Solarium Seconds right side by Corvett crzy, on Flickr I thought this information might help if someone is looking at fabrics, seconds, etc. Oh and thanks vikx, not exactly period correct but I love bright colors, couldn't do muted.
Post by vintagetinyhouse on Jan 26, 2017 11:25:12 GMT -8
Thank you for this tutorial. However, I am certain you did not use a 3/8" cable in a 1/2" track because mine is the same diameter and the 3/8" rope I bought will not fit into the track even without fabric around it. Just FYI.
bellflower62
1962 Oasis - "Bellflower"
Post by bellflower62 on Jan 26, 2017 14:13:17 GMT -8
Awesome info/tutorial and gorgeous awnings...thanks for sharing!
hswatek
Post by hswatek on May 31, 2018 20:54:13 GMT -8
Wow! I am definitely going to be sewing my own awning! I purchased my fabric for my cushions an bunk mattress at Hobby Lobby for $4 a yard. It is upholstery fabric and was on clearance. They have the wide bolts there and always have a lot on sale to choose from. I would suggest spraying your awning with Scotchguard or a sneaker waterproofing spray before putting it up the first time and then redoing the spray each year before your first camping trip.
Thanks for the tutorial! Love ❤️ it!
kudzu
Post by kudzu on Jun 1, 2018 16:36:03 GMT -8
Just saw this and will add my thanks to the list. I am restoring an old wooden boat and bought a old heavy made sewing machine to repair the upholstery and thought if all went well I might try to make a storage cover for it. Will keep this in mind for when we do find our trailer.
wisconsinjoe
Post by wisconsinjoe on Feb 18, 2020 8:22:27 GMT -8
If you are making an awning, consider sewing in some reinforced corner pockets to hold in tent poles that cross (under the awning material) in the middle and get held there with a velcro loop. The awning will dome up and shed water, avoiding the bathtub effect and inevitable drenching collapse. Somewhere in this site I saw a posting about this. We did this to our homemade awning, using 1/2 inch pvc and it works great. Poles were cut about a foot longer than the actual measurement, which then stretched the fabric into the dome shape. Might need to experiment a bit with length. You can buy collapsible aluminum tent poles to most any length needed. Another plus about this is that you only need two ground support poles. We often don't even use staked tension ropes if the weather doesn't forecast strong winds. Rather, we just bury the foot of the poles to keep them from getting knocked sideways. The weight of everything holds it in place.
Post by princesspalace on Apr 29, 2020 7:49:23 GMT -8
SO I wanted to share my DIY Awning with you for my 50's Model Boles Aero. Frist I purchased a replacement awning fabric kit from this website: www.alekoproducts.com/ALEKO-Awning-Fabric-Replacement-p/fab13x10greywht-ap.htmIt was 13 x10 and came with the front awning scalloped edge, the cord and the awning overhead- 79.00 I then went and bought some ball fringe to do the front awning- 9.00 Next I purchased beautiful pink and purple fringe to cover the sides and decorate the front- 40.00 I then got a grommet making kit 12.00 I bought two poles and rope: 60.00 ------------ Total: 200.00
First I sewed on the fringe to the front scallop piece.
Next I sewed on the fringe to the sides and front.
Then I unstitched the first seam on the front piece to give me a bit more sewing room. This also left me with a crisp edge that naturally creased to cause the edge to lay correctly.
I stitched the scalloped edge to the awning.
Lastly, I put on grommets in the place I wanted the poles to hold up the awning and sewed some spare ribbon near the same spot so I could make sure the poles would stay secure.
Voila! Custom awning made out of outdoor grade fabric in two hours!! I figured it out and the same awning would have cost me over 600.00 to purchase. If you did not want to add custom trim you could make this awning quickly for about 150.00 and about an hours worth of work!
I also bought this Mosquito Netting: www.amazon.com/gp/product/B07D564XP3/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I plan on laying my awning out and hand stitching it to the inside of the awning, then sewing ribbons every 2' so it can be rolled up underneath when not needed.
Here is a link to some pictures  <iframe src="https://www.facebook.com/plugins/post.php?href=https%3A%2F%2Fwww.facebook.com%2FBettyShockher%2Fposts%2F10217033834505291&width=500" width="500" height="687" style="border:none;overflow:hidden" scrolling="no" frameborder="0" allowTransparency="true" allow="encrypted-media"></iframe><a href="<iframe src="https://www.facebook.com/plugins/post.php?href=https%3A%2F%2Fwww.facebook.com%2FBettyShockher%2Fposts%2F10217033834505291&width=500" width="500" height="687" style="border:none;overflow:hidden" scrolling="no" frameborder="0" allowTransparency="true" allow="encrypted-media"></iframe>">photos</a>  </span>
Post by ladywendolyn on Apr 30, 2020 13:30:11 GMT -8
I thought I would add in this tutorial from one of the awning Queen's Kirsti. You will either be really inspired to take on this huge project yourself, or convinced to pay her when your done reading. It does show some of the extra work she puts int her awnings that make them nicer than most out there. 16 ft Awning Tutorial-
