Tinkering
Just started on Tinker 1958 Aljo
Aljo 1958
Tires
Jun 2, 2023 7:34:53 GMT -8
via mobile
Post by Tinkering on Jun 2, 2023 7:34:53 GMT -8
Can anyone please tell me what size tires you have on your 1958 aljo I know they are 15 inch but I need to know what works the best
Post by vikx on Jun 2, 2023 12:14:13 GMT -8
Tire size depends on the individual trailer, spring height and wheel wells. The best way to size them is to borrow a spare from the tire store. You certainly don't want the "techs" forcing a too large tire onto the trailer. I used bias ply Cokers on my Aljo but don't remember the exact size. (sorry)
Bias ply tend to be narrower than radius and usually mount easier. Keep in mind that some tires need to be flat to mount with clearance.
Tires
Jun 3, 2023 3:20:47 GMT -8
Post by Teachndad on Jun 3, 2023 3:20:47 GMT -8
Hello and Welcome,
Vikx comment about the tire being flat means that it should have no air in it but it's installed on the rim. For some trailers, this is necessary and then you fill it up with air after it's been mounted on the hub in the wheel well. Tires back in the day were narrower and bias ply. Today's radials are wider.
What length of trailer is your Aljo? That could create a weight standard for the tire size. Make sure you buy trailer tires.
I am assuming you must have some older tires with an older size on it? What size is on there. Conversion tables can be found online from older sizes to modern sizes.
Cheers,
