Post by davesshasta16sc on May 22, 2023 10:00:23 GMT -8
Post by vikx on May 22, 2023 11:43:48 GMT -8
Wide pliers should work but be very careful not to split the aluminum. You might try a heat gun (not too hot) to get the flange to move.
Post by Teachndad on May 23, 2023 20:05:43 GMT -8
Okay, I know not of what I speak, but what if you took two pieces of wood a little longer than the entire length of the window frame and then slowly "sandwiched" the bent frame flange top and bottom and compressed them with 2 to 3 wood clamps? Maybe two planks 1 x 4 each?
I have no idea if it would work or it might be more destructive. Curious to see what others say.
Cheers,
Post by Teachndad on May 31, 2023 19:27:50 GMT -8
Hi,
Do you have an update on your window frame?
It doesn't matter which method you used, just curious how you got along.
Cheers,
Post by davesshasta16sc on Jun 2, 2023 15:25:26 GMT -8
I do not. I believe I am going to try the idea you floated first.
