1937hayes
Post by 1937hayes on May 16, 2023 12:38:39 GMT -8
Hello, I am in the process of Appling marine vinyl to the bottom half of my 1937 vintage Hayes Covered Wagon. I have seen this done on a 1936 same make. my question is after applying an adhesive spray to attach the foam padding, do I need to also apply adhesive spray to the back of the marine vinyl?
thanks Randy
Post by nccamper on May 16, 2023 19:58:00 GMT -8
Welcome!
I don’t have the answer to you question but I’d love to see photos of your camper.
shastatom
Shasta 54,57 1500 58 Airflyte
Post by shastatom on May 17, 2023 9:30:50 GMT -8
I can't tell you for sure but when I have glued vinyl to other items before I sprayed both side.
Post by vikx on May 17, 2023 9:58:32 GMT -8
The glue manufacturer should be able to answer your questions. My guess is both sides.
1937hayes
Post by 1937hayes on May 22, 2023 14:28:50 GMT -8
thanks vikx, I did follow up with company I purchased from. but I have heard that the adhesive could leak through, but owner explained that is waterproof I could add to top of foam and attach the vinyl.
Post by Teachndad on May 22, 2023 21:48:05 GMT -8
Hey Randy,
Can you share any pictures?
Cheers,
1937hayes
Post by 1937hayes on May 24, 2023 11:29:55 GMT -8
here is a photo of my 1937 Hayes Covered Wagon.
Post by Teachndad on May 24, 2023 14:37:28 GMT -8
