dkelley
Post by dkelley on Dec 29, 2022 5:41:15 GMT -8
Post by vikx on Dec 30, 2022 13:25:21 GMT -8
You might find a local metal man to fabricate the plastic edges in metal. They are going to be hard to duplicate; maybe two different pieces? Something to hold the windows in place and another to "trim" the outside edges.
I'm thinking new custom window...
dkelley
Post by dkelley on Dec 31, 2022 5:12:17 GMT -8
You might find a local metal man to fabricate the plastic edges in metal. They are going to be hard to duplicate; maybe two different pieces? Something to hold the windows in place and another to "trim" the outside edges. I'm thinking new custom window... Good suggestons. Thanks Vikx!
Post by vikx on Dec 31, 2022 19:58:20 GMT -8
You might check salvage yards just to see if they have a metal framed window the same size...
Try trailertrasher1@gmail.com. Takes a while to get back to you. Another brand that used that window is Aladdin and also try mid 60s Kit companion. It's a common door window.
Good luck!
dkelley
Post by dkelley on Jan 3, 2023 10:05:46 GMT -8
Thanks for those resources, Vikx!
Post by Teachndad on Jan 5, 2023 6:12:07 GMT -8
Just tossing this idea up there. How about something like this? Just an idea. Find a depth that works. I did a Google search on plastic corner molding and this came up. The goal is to trim the window. Maybe miter the corners like a picture frame. Cheers, Rod
dkelley
Post by dkelley on Jan 5, 2023 9:10:14 GMT -8
Creative suggestion, Rod. Thanks for taking the time to think about it. -David
