Post by justing1976 on Mar 28, 2022 19:10:56 GMT -8
Question for the group. Wiring in a new 7-way plug, as the old harness on our 1967 Kenskill needed to be replaced.
Installed the junction box and pulled back the sheathing on the existing 6-wire harness. The only color not with the existing harness is blue, which is what the new plug uses for the brake controller. We had trailer brakes with the old 6-way setup.
This is what I’m looking at:
Existing 6-way: Black Red Brown Yellow White Green
New 7-way: Black Red Brown Yellow White Green Blue
Thoughts on my wiring setup here, especially for the newer blue brake controller wire? Any feedback would be appreciated.
Thanks!
Justin
chriss
Post by chriss on Mar 29, 2022 11:00:48 GMT -8
Rule of thumb in older trailers. Don't go by wiring colors. Go by what they control or their position. There wasn't a standard for colors back then.
Post by vikx on Mar 29, 2022 13:45:45 GMT -8
I agree. Go by wire position on the plug. And DO NOT TRUST eTrailer when looking for a diagram! There are several 7 way diagrams here. The 6 way will be different color wise. 6 way plugs are often stamped RT, LT, TM, G (ground), S (spare or brakes on some trailers) and aux. Some trailers used the middle pole for brake hot and others used S for brake hot. There are some very good diagrams online showing wire position. www.dieselhub.com/towing/trailer-wiring.html Good clear and concisely marked. If your trailer lights worked, your job is very easy. Remove the wires from the 6 way to test. Look for the GROUND FIRST. It will come out of the 6 way and be connected to the frame, usually by a bolt or rivet. Mark G with masking tape. note: many 6 way plugs used white for ground. Use a 12 volt tester battery to light up the tow lighting, grounded to the frame. Disconnect the ground on the trailer battery(s). Touch each wire (after determining the ground) to the battery hot to find LT for left turn, RT, and TM (tail+markers). You can mark each wire as to what it does. LT will be bright on the left tail light. (often yellow) RT will be bright on the right tail light. (often green) Tail and marker lights will be of lower brightness, lighting the tail and marker lights. (clearance lights) There are only two wires left. One should operate the brake hot and the other is often 12 volt hot or open. Many types of trailers used a 6 way plug back when, so these two are sometimes switched on what they do and different colors. If you touch the tester battery hot to the brake hot, the brakes should "clunk". Also, you can crawl under the trailer and trace the brake wires to the front 6 way plug. I'm guessing the two positions are "S" and "AUX" (12V +) on your 6 way. Here is a thread on testing trailer wiring with a battery: vintagetrailertalk.freeforums.net/thread/11040/testing-trailer-wiringQuestions welcome.
Post by justing1976 on Mar 30, 2022 3:39:26 GMT -8
Thanks for the help, much appreciated!
