halljohns
Post by halljohns on Oct 18, 2021 12:44:59 GMT -8
Does the back window open? If it does wany one know where to get a replacement screen?
Post by vikx on Oct 19, 2021 9:36:10 GMT -8
The back window is often non operational; it doesn't open. If it opens, you would see a way to open it; a handle or mechanism on the inside.
Post by Ten on Oct 20, 2021 21:37:57 GMT -8
Which model Shasta are you working on? The photo appears to be an Airflyte. The original window in the Airflyte did open, it was the push-out style Hehr window. There was a lever that locked it closed, and acted to push the window open from teh bottom, hinging out at the top. The screening was aluminum screen and was integral to the window frame if memory serves me correctly.
