clark
Post by clark on Oct 12, 2021 22:21:13 GMT -8
We're new to the trailer restoration world and I think we've made a mistake. We read that you could treat board most likely to rot with fence post paint. To me that meant the Copper Green wood preservative that you paint or dip fence posts with before you put them in the ground. I think it's like DIY pressure-treated lumber, minus the pressure. So, we applied this stuff to some of the lower skirting boards (edges that face the ground, not the flat outward faces of the skirting). The stuff smells awful and is probably toxic, so we were careful in our use and focused on only areas most likely to rot (exterior corners, inside bottom edges of skirting boards, etc.)- probably less than 3% of the framing. NOW we realize that the copper in this, like the copper in pressure treated lumber, will create an electro-chemical reaction with the aluminum skin. We're far enough along in the project that removing the treated boards would be very difficult and costly. I'm looking for ideas on how to reduce or eliminate any long term consequences of our mistake, without having to tear the trailer down to the floor again. Should I: - Paint over the copper green with asphalt-based fence post paint (two coats) or some kind of primer/sealer
- Count on the vapor barrier/wrap to keep the layers apart
- Spray some galvanizing spray paint on the inside of the skin before we install it, anywhere it might touch, or wear through to touch, the copper preservative. Zinc or Magnesium galvanizing agents would corrode first if electrical contact was eventually made.
- One or more (or all) of the above?
Thanks for your advice, this forum has been amazingly helpful.
Post by danrhodes on Oct 13, 2021 8:16:00 GMT -8
I'd paint it. The house wrap is a common addition also and should provide a very second layer of protection. I'd make sure that you don't have the copper treatment on any boards touching the frame either...
Post by vikx on Oct 13, 2021 10:28:31 GMT -8
It has to dry before you do anything. I mean really dry. I have dried pressure treated boards for months when using them for a building. (to keep the smell down) The bottle says ECO friendly, so not quite as bad as the old arsenic based preservatives.
Once dry, I would paint ONLY the areas that will touch metal. Right where it will meet the frame members and next to the skin.
Wood has to breathe, so I would coat it only where it is needed. If the boards are already bolted down, You could loosen and slip a heavy piece of plastic between it and the frame. (like heavy duty plastic sheeting, 6 mil. or so)
Post by wisconsinjoe on Oct 15, 2021 19:00:34 GMT -8
I'd might think about isolating just the contact areas with a rubber barrier like roofing "water seal," kind of a thin EPDM rubber with adhesive backing. In 3 ft rolls
chriss
Post by chriss on Oct 17, 2021 8:39:32 GMT -8
I'd might think about isolating just the contact areas with a rubber barrier like roofing "water seal," kind of a thin EPDM rubber with adhesive backing. In 3 ft rolls Or that butyl based window flashing will work well. It's my personal opinion that treated lumber should only be used for ground contact and foundation sills. It has no place in a trailer.
