Post by oldtrailer on Sept 29, 2021 11:46:35 GMT -8
This was a camper my grand parents owned. They used it for storage as I was never allowed in it. I couldn't find any markings on it or tags. Had some very old Armstrong Rhino Flex white walls mounted to 5 lug 15' wheels with two different Chevy baby moon hub caps. I've dated the hubcaps to 1950-1951. The camper was supported by cinder blocks underneath on the frame. The tires weren't touching the ground and actually took/held 15psi air pressure. They're dry rotted but are still holding that same psi almost 5 months later. I always remembered it being parked in the same place I'm 39 now. So I think it was parked there 40-50 years and these trees grew around slowly crushing it. The pictures aren't great as the vegetation around it was thick. I have since pulled the trailer frame out from underneath it to make a utility trailer before the rest went to the scrap. I hope that someone may be able to identify what it is? The inside was dangerous and full of gardening chemicals so I stayed out of it.
On the tongue it next to the extendable stand it has has stampings that read General Corp. Quincy, Cal. I think its Quincy but I can't read beyond the c. I can't find any info online. I have the trailer frame, it's C channel steel and very heavy. The spring shackle bushings are greaseable. It has 6 leaf springs. It doesn't have a tube axle but a one piece solid forged drop axle with 5 lug GM stamped hubs. All bearings were USA made Timken and the seals were old Chicago Rawhide seals. I replaced one outer bearing that had a bent cage, repacked them and bought new wheel seals. I will get better pictures of the frame trailer. We tied a large tow strap between the trees and snatched the frame out from underneath it, lol. The old tires went through that with no problems and the trailer rolled right out.
Old Camper #2 by , on FlickrOld Camper #1 by [url=https://www.flickr.com/photos/194038831@N05[/url], on FlickrTrailer Camper #6 by , on FlickrOriginal White Wall by , on FlickrOld Camper #3 by , on FlickrOld Camper #4 by , on FlickrOld Camper Frame #1 by , on FlickrOld Camper Frame #3 by , on Flickr
