carlc
1965 Shasta 1500
Post by carlc on Aug 20, 2021 9:16:43 GMT -8
I am sure this has been answered but I haven't found an answer yet. Please forgive any redundancy.
I am working on the tail lights and marker lights for the tow wiring. How do I ground them? A white wire to eat fixture but do I ground each one to the frame? In the same spot? Or run them all the way back to the j box up by the tongue of the trailer?
I ran both a hot and a ground to the front running lights so we are good to go there. Just curious as to the best way to do the rear tail lights and markers.
Thanks in advance.
Post by vikx on Aug 20, 2021 10:38:51 GMT -8
It doesn't matter how many grounds you have and you can use the entire frame wherever you need one. I always have at least one ground in the back and another in the front for the tow lighting.
For instance, you can run the rear clearance light grounds to the tail location. Then connect both grounds and run one wire either to the other tail light (and down) or run each side ground down to a central rear ground bolt. It's really a matter of what works for you and the trailer.
I like to put another J box in the back to make repairs easy if need be. I run a ground from that box to the frame. My 52 Hanson has 5 grounds: front, rear and 3 from the skins to frame. A ground is a ground is a ground and the more the merrier, in my opinion.
carlc
1965 Shasta 1500
Post by carlc on Aug 20, 2021 11:52:41 GMT -8
Thanks Vikx.
Where would you ground the skin to the frame? Is that just a wire from a bolt on the frame to a bolt on the skin?
Post by vikx on Aug 20, 2021 18:44:37 GMT -8
Usually you can find a screw where the skin curves under the trailer. If not, you can add one, #6 is fine. Drill a hole in the frame and bolt thru it. Ring terminals make the connection secure.
