munk
Post by munk on Mar 13, 2021 9:41:14 GMT -8
I am replacing the sub flooring on my Loflyte. There are carriage bolts that secure the 4’ section of plywood to the frame in the rear, but the section of flooring between the wheel wells and the step down do not appear to have any frame to subfloor attachment points. Does anyone have any experience with replacing the floor on a Loflyte that can give me an idea of the plywood subfloor configuration. Thank you for any help.
Post by vikx on Mar 13, 2021 10:37:27 GMT -8
Welcome Munk,
Most of these trailers had one piece floors and provided a lot of strength at the frame attachments. They can be pieced but be sure you frame/attach so that the original and new become one.
There aren't any "exact" attachment points for the subfloor. I'm guessing your trailer had one sheet in the area and attached front and rear. Any floor to frame attachments will anchor your new subfloor. Be sure your framing in in good condition; you may have to add framing members to support the new floor. Also be sure you have a secure attachment point at the front step down.
