brettstar
Post by brettstar on Jan 16, 2021 19:32:08 GMT -8
My 1970 Utopia has a galvanized steel 'belly pan', which I have removed during my frame-off restore. I plan to reuse it. On top of that, was a ~1/2 inch thick black fiberboard material that sits below the floor 'joist' system and the floor insulation. I'm not sure what the fiberboard is and what to replace it with. I think it may be an asphalt fiberboard. Some posts online suggest it's a homasote product...? I see a few products online at Lowe's and Home Depot (links below), but neither store in my State (Vermont) carry the products nor can even order it... www.homedepot.com/p/1-2-in-x-4-ft-x-8-ft-Southern-Pine-Asphalt-Impregnated-Board-A11230848096/206086210www.lowes.com/pd/Common-0-5-in-x-4-ft-x-8-ft-Actual-0-5-in-x-4-ft-x-8-ft-1-R-1-5-Faced-Fiberboard-Foam-Board-Insulation-with-Sound-Barrier/1000318607 I can find basic homasote sheets that are not coated with anything. That looks like it would absorb water. Would it make sense to try to use homosote but to paint it? Is there another material I should hunt for? I've heard of people using painted or marine plywood facing the street... in my case it would be sitting on top of a stainless steel pan and exposed to water in a few places where pipes penetrate it... seems like a recipe for any wood material to rot. I appreciate any suggestions.
Post by vikx on Jan 16, 2021 20:57:44 GMT -8
You coat most materials with Black Beauty fence paint. It is thick and goopy and dries to a rubber like finish.
Floor cavities do very well with foam insulation. I don't use metal bellies because they tend to retain water if it gains entry into the belly... Some sort of coated belly would protect the foam.
Post by Teachndad on Jan 17, 2021 6:09:00 GMT -8
Hello and Welcome Brett,
I don't know the answer to your question, but try this: Do a search here on VTT for fiberboard and look at the hits that come up. You will find information that might answer your question in other threads about the modern equivalent that can be used.
Thank you for your contribution to the board.
