Post by restoringdalton on Oct 23, 2020 9:05:11 GMT -8
Trying to get original frig & oven/stove out of the camper. The door is 18”. The appliances are 20”. Already removed appliance doors. Any ideas?
Post by vikx on Oct 23, 2020 10:53:02 GMT -8
Welcome. Many of us have been there... Since these trailers are repaired from the outside in, wait until the front is off the trailer, and slide the appliances out then. You have to remember to put them back IN again before putting the skins back on.
Another solution is to widen the door during the build. It depends on the frame config. whether this will work or not.
brave_travels
Rv Technician - Peterborough RV Centre
1973 Winnebago Chieftain
Post by brave_travels on Nov 2, 2020 5:39:16 GMT -8
Its very common to have to remove a window to remove an appliance, measure them all up and see if one is wide enough, beside that vikx's solution is the best by all means!
