reeb
Post by reeb on Sept 25, 2020 8:24:38 GMT -8
Hello I just bought a 59 traveleze and everyone seems to be out of j rail. Does anyone know where I can get some? Is this no longer being made? Can I use something instead of j rail I was thinking maybe some aluminum angle not sure if this would work. Thanks
Post by vikx on Sept 25, 2020 9:36:04 GMT -8
Try Interstate RV Metals in Oregon, Hemet RV in Calif and SoCal Teardrops. Most RV shops also sell it or can order it. Not sure how long they will ship; I think it's 8'.
reeb
Post by reeb on Sept 25, 2020 9:40:27 GMT -8
Thanks Hemet is out I will try the others
theresa
Post by theresa on Sept 25, 2020 12:26:00 GMT -8
Yes, Steve at Hemet told me he was out and didn't know when he'd get some in. So I'm stuck using my old crappy stuff on new skin.
57heaven
Post by 57heaven on Sept 25, 2020 13:15:54 GMT -8
Is most all of the j rail the same extrusion? I do aluminum extrusion fabrication for a living and if it got to a point where you just can't find it you could have a die-cut and extrude new j rail but it would take a few orders to make it worth the cost. Any aluminum extrusion shape can have a new die made so if there was something else out of extrusion that people can't find it is possible to remake the actual extrusion die.
Post by turbodaddy on Sept 25, 2020 17:58:20 GMT -8
A sign of the times, there are all sorts of things unavailable now. Back in July I started to build a shed and chicken coop. At the time there was no pressure treated lumber available here. I did find some of those rounded edge garden timbers and ended up using them. Time for old fashioned ingenuity I guess.
aries
Post by aries on Sept 25, 2020 17:59:26 GMT -8
Inch and a quarter for some of these PNW trailers would be great but a single order for myself,yeah not cost effective.Company’s are either out of (wide rail)or very little stock,but since have An eye on pristine rail from soon to scrap Anderson all this Hemit 3/4 take’n up me space🤔
Post by vikx on Sept 25, 2020 20:48:37 GMT -8
J rail can be straightened almost as good as new with patience. I've only had to use one short piece of new J rail on many many trailers.
Post by John Palmer on Sept 25, 2020 21:38:06 GMT -8
You have several things going on here, lets try to sort them out.
#1 "J" rail, Rain Rail, Drip Rail (all the same item) is not an "extrusion". No need to make a die to run it. It's formed from flat aluminum in a roll type machine. There's no way you are going to make it as cheap as you can buy it. It runs about a "buck a foot", up to about $25/$30 for a sixteen foot section depending on where you are forced to purchase it.
#2 Awning rail "is extruded" for a example. It's a completely different way of manufacturing.
#3 Truck Shipping is the issue with this product. It's hard and expensive to ship a sixteen foot aluminum rail that is so easily damaged. A dealer/distributor would likely need to order 50 to 100 sixteen foot sections at a time in order to make the freight cost amortize out.
#4 Length, you want to "purchase only, full sticks, of sixteen feet", because it's lots easier to shape smooth bends when you eliminate the joints. You need three sticks to do a small canned ham when reusing the awning rail.
#5 UPS and FedEx will only ship 94", to 96" maximum length items, so internet vendors cut your perfectly good sixteen footer in half ruining your piece. They compound the problem by requiring you to purchase $$ a separate plastic shipping tube.
#6 As a customer, you have very little clout when you need only three sticks, but your dealer needs to place an order for 100 sticks to get his freight costs per stick into a reasonable amount.
#7 The current supply of all kinds of products currently is very poor due to manufacturing cutbacks. For example, paint manufacturer's cannot supply the paint demand due to shortages of raw materials and shortage of paint cans.
John
theresa
Post by theresa on Sept 26, 2020 7:08:50 GMT -8
John is always the voice of reason and writes things clearly enough for anyone to understand. As far as the current supplies of anything, so true! My local convenience store owner said even things as simple as the basics (beer and hard ciders and seltzers) are all on short order or back order because of the shortage in aluminum can productions.
Post by vikx on Sept 26, 2020 12:29:37 GMT -8
Guess I'll start drinking my beer in bottles...
Paid $65! for a garbage can yesterday. Prices are way up.
