dhosh
Post by dhosh on Aug 3, 2020 19:25:23 GMT -8
I recently acquired a Lite-King propane mantle wall mount lamp. I need to get a photo and post... But can these be run on small 1# propane tanks, or do they need to run off a bigger tank... Like 20#. I assume they should be in front of a regulator of some sort? My camper trailer no longer has propane lines run.
The ceramic nose has 3 concentric rings where the mantle would go. Might these be to mount a hard mantle, or use the tie on versions?
Lastly, I don't have a globe. The lamp has a witr spring clip to hold one on. Assuming I can find one to fit, should they be Pyrex, or were they plain glass?
Post by vikx on Aug 3, 2020 22:12:17 GMT -8
You will need a regulator to run the lamp. I haven't used a regulator on the small bottles but suppose it could be done. Guessing there are regulators on some items that run on the small bottles but not sure.
I would have to see the lamp to determine which type of mantle and globe it needs.
dhosh
Post by dhosh on Aug 4, 2020 4:49:19 GMT -8
Here are a few shots: They didn't all post the first time .. Thanks! Dennis
dhosh
Post by dhosh on Aug 4, 2020 6:28:11 GMT -8
You will need a regulator to run the lamp. I haven't used a regulator on the small bottles but suppose it could be done. Guessing there are regulators on some items that run on the small bottles but not sure. I would have to see the lamp to determine which type of mantle and globe it needs. There are often regulators located at the tank ... and some small appliances like a portable Coleman stove, have what appears to be a different one. If I located one at the tank, that would suffice for all devices behind it?
Post by vikx on Aug 4, 2020 9:41:22 GMT -8
I would not trust the regulator for other items. The pressure in a trailer needs to be 11" water column so the lamp needs that to operate safely. Many little bottles provide full pressure which is way too high for RV appliances. There is an adjustable regulator sold but it looks like it needs extra fittings to operate with the small bottle. www.amazon.com/MENSI-Pressure-Regulator-Adjustable-Regulate/dp/B074FTXL3PTake great care with this project, as a mistake could cause a lot of damage.
dhosh
Post by dhosh on Aug 4, 2020 12:38:02 GMT -8
For the regulator at the tank, I meant I often see regulators at the tank .. maybe 2 stage single regulators? Wondered if a proper one was at the tank, if that was sufficient for most any appliance (including this lamp) to run properly? The other option I was wondering, is what you referenced with the link. If I used a 1# bottle ... would I need a regulator. Looks like the answer is yes. That one in your link would screw right on to a 1# tank. I would need to fenangle (sp?) fittings to go from it to the lamp. Looks like the proper and safe thing would be to bag the 1# bottle idea, and just plumb a line back to the tank, with a regulator regulator there. The regulator at the tank, then, should be one of these?
Or, maybe this one?
Post by vikx on Aug 4, 2020 20:49:40 GMT -8
I agree, bag the 1# bottle and go with a tank on the tongue. You will need a dual stage low pressure regulator with a single outlet for one tank. If you have two tanks, you will need a dual stage auto changeover regulator. Most of my trailers only have one tank. The little BBQ regulator is not legal for an RV; all regulators must be dual stage. Here is a single regulator: www.homedepot.com/p/Gas-One-5-ft-2-Stage-Propane-Regulator-with-Hose-2131-05/312460903 Keep in mind that a horizontal regulator like this needs space after it's attached to the tank. There are different configurations to research before you make a decision.
dhosh
Post by dhosh on Aug 5, 2020 4:22:32 GMT -8
Very good... I understand they need to be covered, as well. Good to know, as I assumed coverings were just for aesthetics. As long as I'd have a regulator and a line run (I'd run copper to the lamp), I might as well run a line for a small stove also. Thanks!
Post by vikx on Aug 5, 2020 9:56:39 GMT -8
A vintage trailer doesn't need a covered regulator. Just be sure the vent is in the proper position so water doesn't get in.
Gas lines to stoves are 3/8 OD while lamps operate with a 1/4 line. You can tee the 1/4" off the main 3/8 line going to the stove area. A brass 3/8 flare fitting at the front will connect your tank hose.
