Post by wisconsinjoe on Jul 23, 2020 10:20:34 GMT -8
On my scratch build I'm studying electrical wiring. I want to be able to dry camp, so I plan on everything to be 12 volt to run off a battery system that is maintained by a charger/converter (when hooked to shore power) or possibly to a (future) solar panel. I want to run about 8 LED lights, a Fantastic Fan, a 3-way fridge, an LP stovetop with electric ignition, and a couple of 12 volt outlets to plug in device chargers.
Also, I will need to run the tow vehicle wiring to running, tail, and blinker lights, and electric brakes.
I'm looking for a good clear tutorial in print or video. Does anyone have ideas for me?
I have so many questions. From wire types, sizes, and colors to grounding, battery monitoring and safety. Been reading the posts here and learning, but would love to find a comprehensive guide.
Post by vikx on Jul 23, 2020 11:31:49 GMT -8
I can help thru email. PM me for my address.
roadtripper
Post by roadtripper on Jul 25, 2020 6:04:59 GMT -8
A book I’ve learned a lot from is “managing 12 volts” available at vts or amazon. There is a lot of solar info there too. I’m a big fan of solar and have my camper set up with it. If you want solar maybe in the future, I’d suggest making sure your battery system is large enough. One rule of thumb is one amp hour storage for one watt at the solar panel. For example, I have two 100w panels for 200 watts, and two 6v golf cart batteries wired for 12 volts that provide a little over 200 amp hours of storage. At times it’s a little overkill, but we can boondock for days, no problem. I have the 3 way fridge and like it. It’s a real pig on 12 volt but my panels will run it daytime in good sun, and on long road days, but we mostly run it propane, which seems to work even better than 120v, and the fuel use is minimal. There are very good 12 volt batteries out there, but in my opinion, avoid the cheap “rv/marine” type at Walmart. These aren’t true deep storage type. Some here probably do ok with them though. You need to calculate your worst case amp hour use per day, times how long your out, add a little extra, and that will tell you your storage needs. And you only use off the top of the capacity. And one more note. The portable type panels are real nice and have gotten much more affordable lately.
Post by wisconsinjoe on Aug 3, 2020 12:14:45 GMT -8
A book I’ve learned a lot from is “managing 12 volts” available at vts or amazon. There is a lot of solar info there too. I’m a big fan of solar and have my camper set up with it. If you want solar maybe in the future, I’d suggest making sure your battery system is large enough. Thanks for the tip. I'm very interested in making this camper at least "solar ready." Gonna look for that book. Worried about juggling battery charging between the tow vehicle, the converter charger, and solar. Think that book might help?
roadtripper
Post by roadtripper on Aug 17, 2020 6:10:20 GMT -8
Hi joe, sorry I just saw your question. Yes, I think the book would help. Another source I used was the company I purchased materials from. It’s AM Solar in Oregon. All they do is rv solar.
datac
1957 Cardinal
Post by datac on Aug 17, 2020 10:02:38 GMT -8
