azshastanut
1957 Kenskill 16T
Post by azshastanut on Jul 14, 2020 10:49:18 GMT -8
Can anybody who has a 1500 look at the Hehr part number stamped on the exterior mounting flange of the two five pane Jalousie windows that are mounted on the sides behind each dinette seat. I think it is 1626 2701 185 221, but would like to confirm that is correct. I have a pair of 1626 2701 185 291, that are 7 inches wider. I am converting a 59 Shasta Airflyte to Jalousie's to eliminate the poorly designed water leaker, frameless original sheets of glass. An added benefit of this conversion is much improved air circulation. Has anybody else done this conversion? If you are thinking about doing it, realize that it will require new upper and lower skins on both sides.
Post by Teachndad on Jul 17, 2020 6:11:34 GMT -8
Can anybody who has a 1500 look at the Hehr part number stamped on the exterior mounting flange of the two five pane Jalousie windows that are mounted on the sides behind each dinette seat. I think it is 1626 2701 185 221, but would like to confirm that is correct. I have a pair of 1626 2701 185 291, that are 7 inches wider. I am converting a 59 Shasta Airflyte to Jalousie's to eliminate the poorly designed water leaker, frameless original sheets of glass. An added benefit of this conversion is much improved air circulation. Has anybody else done this conversion? If you are thinking about doing it, realize that it will require new upper and lower skins on both sides. Gary, Glad to see your still working away at your projects! Rod
