Post by cmgaggie123 on Jun 22, 2020 16:50:34 GMT -8
Question for y’all. I have heard grounding each individual light is preferable. Does this mean in addition to the ground wire at the tongue or instead of that one wire that would run to each light.
aslmx
Post by aslmx on Jun 22, 2020 18:36:25 GMT -8
I ran one to each light. Probably not needed but I had the wire and the time so I went ahead and did it.
Post by vikx on Jun 22, 2020 19:38:00 GMT -8
Most of us run a ground to each light. The skin doesn't always maintain the ground and the extra wire is insurance that the lights will continue to glow. You can run the ground wire from light to light and finally to the trailer frame. Each light ground doesn't have to go straight to the frame. Just be sure your connections are secure.
