drkwood
Post by drkwood on May 26, 2020 9:03:56 GMT -8
My 1963 Holiday Rambler has an amazing pattern on the bathroom/shower walls. Unfortunately, it also has rot behind the wall. So we are ripping it out and replacing it. I want to find a way to reproduce the pattern. It's cream with brown and gold in the pattern. Most places i have contacted said they could not do the gold part of the pattern. I think we are going to put in paneling, then a thin bathroom wall panel to waterproof it. I want to find a way to cover that with a vinyl or other waterproof covering that I can have custom printed with the old pattern. Any resources are appreciated.
Post by vikx on May 26, 2020 10:01:01 GMT -8
You can save the existing paneling and re-use it. Even if there are bad parts, most of it should be OK. The old bathroom paneling is tuff stuff...
I've never found a place that would custom do gold. You might be able to paint a panel, then use poly to waterproof and finish.
