littlegemini
Hi I'm andrea. Renovating my 1968 Williamscraft camper
1968 Williamscraft
Post by littlegemini on May 24, 2020 15:02:58 GMT -8
littlegemini
1968 Williamscraft
Post by littlegemini on May 24, 2020 15:05:05 GMT -8
Also - the top half of the skin is in ok shape. The bottom half is not. How do I go about just replacing the bottom section?
littlegemini
1968 Williamscraft
Post by littlegemini on May 25, 2020 11:24:15 GMT -8
ALso- the bottom piece is in such bad shape. I am going to look into getting something locally to replace the bottom half. Can I just overlap them with putty and screws or do I need a fancy seam? Anybody? I think replace from the top of the window down. UGH I am having a hard time adding a pic of the back of the camper. Might start a new thread.
Post by vikx on May 25, 2020 11:28:38 GMT -8
The seam almost looks like a factory crimped seam. Can you post some more photos further away so we can get an idea what you actually have?
littlegemini
1968 Williamscraft
Post by littlegemini on May 25, 2020 11:28:50 GMT -8
Post by vikx on Jun 4, 2020 22:37:11 GMT -8
If the lower piece slips down and out of the upper piece, it is a Pittsburg seam. If it won't come apart at all, it's probably factory sealed. From the look of the trailer, it has Pittsburgs.
