CorvettCrzy
'58 Corvette, '64 Franklin
Post by CorvettCrzy on May 15, 2020 16:41:27 GMT -8
I have seen at least a couple of threads where people have jacked up their trailer in tact and pulled the floor and frame out from under to repair. We need to do this with the Franklin, so I'm looking to get suggestions and learn anything I can.
I cannot remember who it was so hoping one of you has a better memory than me. Was it you, or do you have any idea who/what thread it was - they were in the Restorations section.
Thanks for any help.
Post by vikx on May 16, 2020 9:38:27 GMT -8
I lifted my Red Dale body after discovering the floor was too far gone to repair. I attached 2 x 4s to each side and used rachet straps to the rafters. My rafters are heavy duty 2 x 8s and capable of holding a lot of weight. I don't recommend lifting with manufactured trusses. 002 j Body Lift (2a) by vikkx, on Flickr 002 j Body Lift (1) by vikkx, on Flickr Luckily, the frame was in great shape; just needed cleaning and paint. I have more photos if you contact me.
Post by nccamper on May 16, 2020 12:35:23 GMT -8
A couple of photos from another thread you might find interesting.
Post by Teachndad on May 17, 2020 9:31:59 GMT -8
Hi Friends,
Look up the Aloha restoration thread by RinTin. He started out lifting and then changed course for a more conventional approach.
I did it with my Westerner in my restoration thread. I can't post with details right now but will come back with links and my experience later when I have more time.
Cheers,
Post by Teachndad on May 17, 2020 22:11:25 GMT -8
Hi Friends, I patterned my method for raising the body much like Rin tin does in this thread on page 2. vintagetrailertalk.freeforums.net/thread/4148/1965-aloha-project?page=2Here is what my Westerner looked like raised up and on sawhorses.
Here is how we did it. Go here: vintagetrailertalk.freeforums.net/thread/3598/andy-57-westerner-restoration-thread?page=2 and scroll down to post #19 and then follow the pix all the way down. I pretty much show how we did it. Your tires will have to clear the 2 x 4 that runs latteraly across, so you need to raise the body so the tires clear when you pull out the trailer. In hindsight, I guess I could have lowered the air pressure or pulled the chassis out on the drums to lower the required height of the body to pull out the chassis. Additionally, here is a thread over at RYT that’s about 8 years old, but might be worth reading. www.tapatalk.com/groups/repairingyesterdaystrailers/remove-the-frame-without-tearing-down-the-body-t3357-s10.html You really need to be careful and safe when you do this. Take it slow and easy raising it a little at a time. There are other methods to lift it and then support it. With the method we used, once on the sawhorses, the frame sat solidly on my driveway with no issues. Getting it to that height was nerveracking. My small floor jack was small. It can be seen in one of the pictures. The uneven and rough surface of my driveway caused the jack not to roll when it lifted. The result was that the jack got stuck in one place and wanted to pull the body in one direction. At the time, I didn't realize why this was happening. It created an almost “walking” motion for the body. I should have used a much larger floor jack that can roll as it’s jacking or lifting. Lowering it was much easier. Maybe someone else will pipe up. Let me know if you have any other questions. Rod
CorvettCrzy
Post by CorvettCrzy on May 30, 2020 9:43:23 GMT -8
@vikx mobiltec nccamper Teachndad RinTin Thank you so MUCH!! This was exactly what I needed, all of this is superb information. I can't express how much we appreciated everyone sharing their knowledge. We wouldn't be trying it at all if others hadn't been willing to share their experiences. And we wouldn't be able to retain the beauty of this old camper. We will read every detail you have provided. I especially want to thank those who take the time to document and explain everything in such detail! I know it's time consuming and a labor of love, and it is appreciated. I have a favorite plaque "I can explain it to you, but I can't understand it for you". You all take such care in explaining the tasks that the average person can follow along. One of the many reasons I'm still here 7 years after finding this wonderful site and all the wonderful people!
