PT
Post by PT on May 13, 2020 11:25:59 GMT -8
Post by nccamper on May 13, 2020 17:42:12 GMT -8
I like your plan. Not a lot of room for error.
The .03 skin bends well and doesn't kink as easily. Do you have a small piece of the heavier skin to experiment with?
ekimnamniets
Post by ekimnamniets on May 13, 2020 17:53:47 GMT -8
What diameter pipe would give you the radius you need? Just guessing 1 1/2" or 2" (there isn't much in the photo to get a reference from). Thinking out loud, wouldn't black iron pipe be better? Seems that p.v.c. would tend to flex too much. With skin laid flat on table let the area to get the radius hang off the edge of the table, clamp the pipe down on both ends and start dolling a little at a time down the entire length of the pipe. Back and forth in small increments until you get what's needed. Many ways to skin a cat (sorry vikx) but it's the way I'd go. Oh, and use a rubber mallet.
PT
Post by PT on May 14, 2020 9:03:26 GMT -8
Thanks for the feedback - I can eyeball the likely size of the pipe I need today when I'm out at the shop. I initially thought about a rubber mallet but you'll be able to see this area and I always end up with a ripply surface when I use a mallet no matter how careful I am. I'll also grab a piece of old skin out of the rafters and see what its edge looks like.
ekimnamniets
Post by ekimnamniets on May 14, 2020 15:47:55 GMT -8
If you're creating ripples or a pie crust effect, you trying to work too large of an area at a time. Or trying to move it too far in a single pass. Less is best. Small increments and a whole bunch of back and forth. Same process will work on mild steel sheet metal. Moving too much or too far on a given pass will start stretching the material.....bad deal.
