Post by wisconsinjoe on Mar 3, 2020 7:13:15 GMT -8
Been wondering how to poke holes through new aluminum skin to access wiring for exterior lights. Two problems: locating exact location and not damaging wire (or inadvertently pushing wire back into the hole where it could get unreachable). Surely there must be some tricks for this task
Post by vikx on Mar 3, 2020 13:37:59 GMT -8
I determine the general location for ext. lights from the old skin, then build backers to help anchor each light. I leave a space to poke the wires into the wall cavity. The new skin is cut to match the wall and marked at each light location. I drill an inch hole at the light space. Leave the wires a little long and they won't disappear plus the space will contain them. I use wire wing nuts to attach the light wiring; makes for easy repairs. Here is my Cardinal build: 58cardinal.shutterfly.com/pictures If you scroll thru the albums, you'll see the skin install, the hole and the final lights. The Cardinal had 1 1/2 walls so the foam insulation helped hold the light wires in place. Most of the time, the space is a wood framed "box" at the light location. Here is an example of tail light boxes made out of one bys. 006 x BB Locates (8) by vikkx, on Flickr
Post by nccamper on Mar 3, 2020 15:48:39 GMT -8
vikx covered it but I'll add that I make the wire long and curved in a circle at the area of the light so if I'm off 1" it's no big deal. I can always find the wire. I also make my holes really small and fish for the wire with needle nose pliers.
