tehachapibob
69 Shasta Stratoflyte
Post by tehachapibob on Aug 20, 2019 16:33:53 GMT -8
I have an 18' '69 Shasta Stratoflyte that I wanted to add a small (10gal) gray water tank into. Has anyone comeup with a good location in this model?
Post by danrhodes on Aug 22, 2019 14:41:15 GMT -8
There used to be a user here named John Palmer who would just use large diameter ABS sewer pipe for grey and black water tanks. You can use fittings to make it into any shape that fits between the frame rails, make it any capacity by just using more pipe and use a standard cleanout as a drain.
Post by turbodaddy on Aug 27, 2019 4:02:40 GMT -8
Another idea, install a porta potty (We like Thetford Curve,about $100) and use the existing black water tank for gray water.
