violamomof4
1954 Jewel
Post by violamomof4 on Jul 13, 2019 10:09:23 GMT -8
New j-rail ripping at screw holes when try to bend around trailer. HELP!!! What do we do?!?! Husband is at his whits end!!! Expensive stuff to have ripping! 😳😳😳😳😳
Post by nccamper on Jul 13, 2019 11:24:05 GMT -8
I'm not an expert, but I've had cracks when trying to bend at the screw point, when trying to install jrail in the cold (not really applicable in July) and when I didn't pre drill the holes.
Do the brakes appear just when bending or also while drilling in the screws?
I considering one of these shrinker stretchers:
violamomof4
1954 Jewel
Post by violamomof4 on Jul 13, 2019 13:52:54 GMT -8
Thanks for advice. Holes are already pre-drilled. I think he needs to shape it first before he puts it on the trailer. Will try that. I wondered if he had the wrong size/style of screws or was tightening screws too tight. Just brain storming. What exactly are the stretchers? Thanks again! Erin
PT
Post by PT on Jul 13, 2019 14:15:01 GMT -8
One thing that helped me was not bending it using the screws as the main pivot points. This places all the pressure of the bend at one point (hence the ripping) and makes for a bend with a series series of straightish lines instead of a nice continuous curve
I think Larry shows this in one of his vids... you can use the front/rear skin where it is supported by the edge boards to make the rough shape and then you can fine tune as you move from screw to screw when you install it. This is challenging as you're pushing on the sharp edge of the J-rail against the supported trailer skin but it works. You can place a towel under the J-rail edge (maybe tape the towel to the skin as you work around) to avoid scratching the skin and wear a pair of gloves.
One person would need to hold one end of the J-rail firmly against the skin while the other moves along applying pressure to make the rough bend. With the rough continuous bend made it should line up fairly well when you go to screw it in and the smaller adjustments you need to make at the screw points are much less likely to cause tearing.
Hope this makes sense :-)
Post by vikx on Jul 13, 2019 20:46:32 GMT -8
Another thing that helps (but is a huge PAIN) is heating or 'annealing' the aluminum. I've not had as much luck with new J rail sold in RV shops. We straighten the old and re-use it. Most can be made to look like new. From what I understand, the teardrop place sells softer J rail. They call it drip rail. www.socalteardrops.com/parts.php?cid=2&pid=28
n2hcky
1967 Serro Scotty Hilander
Post by n2hcky on Jul 14, 2019 6:39:13 GMT -8
A note about the annealing process. Neat trick.....the ink from a black "Sharpie" marker. The temperature that it disappears when heated is also the correct temp to anneal aluminum. Just an FYI
Post by vikx on Jul 14, 2019 20:04:27 GMT -8
Great tip N2hicky!
violamomof4
1954 Jewel
Post by violamomof4 on Jul 15, 2019 4:58:57 GMT -8
One thing that helped me was not bending it using the screws as the main pivot points. This places all the pressure of the bend at one point (hence the ripping) and makes for a bend with a series series of straightish lines instead of a nice continuous curve I think Larry shows this in one of his vids... you can use the front/rear skin where it is supported by the edge boards to make the rough shape and then you can fine tune as you move from screw to screw when you install it. This is challenging as you're pushing on the sharp edge of the J-rail against the supported trailer skin but it works. You can place a towel under the J-rail edge (maybe tape the towel to the skin as you work around) to avoid scratching the skin and wear a pair of gloves. One person would need to hold one end of the J-rail firmly against the skin while the other moves along applying pressure to make the rough bend. With the rough continuous bend made it should line up fairly well when you go to screw it in and the smaller adjustments you need to make at the screw points are much less likely to cause tearing. Hope this makes sense :-) Wow!!! Thanks so much for all the info!!!
violamomof4
1954 Jewel
Post by violamomof4 on Jul 15, 2019 4:59:33 GMT -8
Nicky Thanks so much! Great tip
nate
1963 Comet 17'
Post by nate on Sept 14, 2020 5:45:44 GMT -8
I just installed my drip rail and we had this happen right away. Our solution was to make a bend template out of 3/4" plywood. We cut out copies of the bend with a jig saw, screwed the template to our picnic table and then bent the rail around the template. We got pretty close to the bend of the trailer and then could make little adjustments as we screwed it on. It worked very well. I hope this makes sense. And helps. Good luck.
Post by John Palmer on Sept 14, 2020 10:29:37 GMT -8
I just installed my drip rail and we had this happen right away. Our solution was to make a bend template out of 3/4" plywood. We cut out copies of the bend with a jig saw, screwed the template to our picnic table and then bent the rail around the template. We got pretty close to the bend of the trailer and then could make little adjustments as we screwed it on. It worked very well. I hope this makes sense. And helps. Good luck. YES!!!!! Somebody finely gets it! It's called "metal shaping". First, Rain Rail, "J" rail, and Drip Rail is all exactly the same thing with different names. It might look different if it's made by different companies. It's just soft aluminum that has been formed to shape. It comes in 16' sections, and is NOT cheap to ship due to the size. It sells for about $2/foot, or $25 to $30 a stick. Any "local" RV parts store can obtain it from their normal wholesale suppliers, but they choose to not stock it because it's very easily damaged and would be hard to make a profit. You do not want to order it "on line" because it has to be cut down to 96" to comply with UPS and FedEx shipping sizes. You want to have long smooth pieces (easier to bend), NOT a bunch of extra end seams. It usually takes three, 16' pieces to do a small canned ham trailer. Two to do the left side, and one (with a awning rail" to do the right side. It's much easier to use new soft, not old oxidized metal, and to polish it "before" you shape it to your trailer. Use 1" #8 Pan Head "stainless screws" to attach. Do not use the self taping flat head sheet metal screws in the above photos. They are not long enough, and do not have a nice deep thread. Buy you screws by the hundred. You usually get a bulk discount, and they run about 9 cents each. Note: You can buy rain rail when you place your RV skin order from my sponsor at Hemet Valley RV. Steve sells rain rail, but no longer sells awning rail. The biggest advantage is "will calling" or "shipping" the rails when you obtain you new skins for freight savings. Since the rail is made of very thin, and very soft aluminum you will find that it tears "if you use the internet method, of Screw, Bend, Screw, Bend.......". In my annual VCT Boot Camp class on Metal Shaping, I teach the method of pre-bending the rails using wood templets. One property you have to understand about bending metal is called "spring back". I would guess the percentage of spring back on aluminum is close to 15-20%. Because the metal springs back, you cannot just cut out a single templet the shape of the trailer to bend your rails. All you need is some different radius bends, start at the top, make some reference points on the trailer and the rail so you come back to the same point each time. Then work your way down. Hold the radius up to the curve, mark what part of the radius you want, then bring it down to the work table and make that part of the bend. It's easier to demonstrate, harder to explain the method. You can shape the rain rails down to about a 12" radius (without tears) with this templet method. Shrinkers/Stretchers. I use the Lancaster (USA made) brand in my class. They are the original quality made product that Harbor Freight copied. You do not need to buy these advanced metal shaping tools to just shape soft rain rail. I use them to show how my students can form 3/4", 1", and 1 1/2" by 1/16" aluminum angle into curved shapes like is used on round window and fender lip trims. Annealing is very easy to do, you can find lots of information on the net. First, it's not needed to bend rain rail, if you use the templet method. I teach annealing mainly for bending extruded awning rail. The thicker extrusion is "much more difficult" to shape and it helps to soften the metal hardness before you begin. I use an acetylene torch. I first coat the working piece with carbon soot (you could use a candle, or even the felt marker ink), then I slowly heat the metal to burn off the soot. At precisely the point the soot burns off, the metal is hot enough to change hardness, and you have to STOP heating the metal because it will melt. Again, this is necessary for bending new/or re-bending old extruded awning rails. Not necessary for bending rain rails unless they are really old. Work Hardening.......Have you ever tried to bend a new 3/8" copper tube, and tried to bend a fifty year old 3/8" copper tube? BIG difference correct. The new tube is soft and easy to bend, the old tubing is very hard and stiff to bend. The inside diameter, the outside, and the wall thickness are all exactly the same. So what's the difference? Metal work hardens, the metal becomes harder. This can happen in fifty years of heating/cooling cycles. It can also happen due to shaping like happens during the extrusion process. You can reverse the hardening by using the annealing step. You will know when it's needed because the metal will not easily bend. Class over, John
Getnold
1957 Westerner Pony Express
Post by Getnold on Sept 14, 2020 14:27:33 GMT -8
I just did the j-rail and one spot cracked at the screw on the tightest turn. After that we went much slower and tried to prebend and not just where screws went. If you look at the spot where the last screw was installed you can actually see the metal start to "flow" and stress a little, that is when it's time to slow your roll so as not to cause more stress on that spot. Then we spent time bending at different locations beyond that point. Hard to explain. It worked for us anyway. Our j-rail came from Hemet btw.
Post by mobiltec on Sept 14, 2020 16:12:15 GMT -8
Sorry I didn't see this earlier. I have lots of videos on J Rail for both Toasters and Canned Hams.... Website is www.cannedhamtrailers.comI only use the Shrinker Stretcher on toasters because of the really tight bends. Even then it elongates the holes... But it works.
