violamomof4
1954 Jewel
Post by violamomof4 on Jun 26, 2019 11:38:15 GMT -8
Is this the table support? If so, how in the world do we use it and mount it etc??? Thanks for help! Erin & David
Post by vikx on Jun 26, 2019 19:57:30 GMT -8
Mount one half on the wall (be SURE there is sound support behind it) and the other 1/2 hangs over the top. One bracket should have a bit of an offset to allow the other to fit over the curve. Hope this helps.
Post by Teachndad on Jun 27, 2019 18:33:49 GMT -8
Hi Erin and David,
They are mounted horizontally. One is mounted centered on the front wall where the dinette cushions are generally located. The other part is screwed into the rear part of the table. That's the part of the table that will be closest to the front wall.
Hope that helps,
Post by nccamper on Jun 28, 2019 8:01:56 GMT -8
The wood piece that supports the bracket is screwed into a framing piece behind the birch panel.
How it is attached to the table.
Post by Teachndad on Jun 28, 2019 8:41:20 GMT -8
A picture is worth a thousand words or even 100.
Nice!
