nate
1963 Comet 17'
Post by nate on Jun 18, 2019 4:56:26 GMT -8
I'm wiring up the 12v system in my trailer. I used 14ga throughout but am wondering what size to run from my battery at the tongue to the 12v fuse panel, about 15 feet away. Is 10ga enough? Does that change if I run a converter or inverter?
kudzu
Post by kudzu on Jun 18, 2019 7:56:04 GMT -8
Wire size is based on the load it will be handling. So you really need to figure out its maximum load, how many amps you could pull through the wire and then pick your wire based on that.
Post by vikx on Jun 18, 2019 21:01:28 GMT -8
Many converters require 6ga from the battery. Without a converter, I would go minimum 8ga, 15 feet is a long run.
