haze5736
1970 Fan Lee Liner 16'
Post by haze5736 on May 30, 2019 6:38:24 GMT -8
Can anyone tell me what the grommets are called where the gas line goes up through the floor? They are plastic, just larger in diameter than the copper tubing with a flat end on one end for stapling to the underside and they protrude up through the floor on the inside. And where might I find them? Thanks.
Post by vikx on May 30, 2019 20:44:54 GMT -8
Grommets and there's lots of different kinds. You can use anything to protect the tubing, even a piece of garden hose and quick ties. Take a look for rubber grommets, plastic grommets and don't forget marine grommets. You'll find something that will work.
WhitneyK
'67 Shasta Compact
Post by WhitneyK on May 31, 2019 19:32:05 GMT -8
chriss
Post by chriss on May 31, 2019 21:00:14 GMT -8
Proper name for them is tube insulators. Check the plumbing section of any hardware or big box store. Problem is I don't remember seeing them for anything smaller than 1/2" tubing. You can also check ACE in their hardware drawers. They always have a strange selection of rubber grommets and sleeves that may work better.
