brian1313
Post by brian1313 on Apr 29, 2019 5:39:56 GMT -8
We have a porta potty in our camper so I only need a portable grey water tank for my camper but the outlet under the camper where the water drains and the portable grey water tank would hook up has no threads or anything on it. Is there an adapter out there that can be put on this? Does it need to be glued on somehow?
Post by vikx on Apr 29, 2019 20:27:01 GMT -8
Find a barb to fit inside with male hose threads on the end. Most of mine have a 3/4 hose type drain. If yours is PVC or something else there will be fittings for it. If you want to replace the drain, "tractor breather tube" is very flexible and easy to install the fittings. The trouble is, I'm not sure it is called breather tube everywhere....
Post by Ten on Apr 29, 2019 21:37:47 GMT -8
I am imagining (dangerous, I know) that it is probably 2" ABS (black plastic) or 2" PVC (white plastic). Check with your local RV dealer for the Valterra fittings, which would have the hookups for the modern flexible sewer connector hose. They should be the same as what would be on your portable tank. I had a link for a dealer that sold these, but can't locate it now.... Will check to see if I can find though....
oakback
Post by oakback on Apr 30, 2019 4:29:00 GMT -8
Can you take a picture of the outlet? How about with a tape measure next to it?
Post by mobiltec on May 10, 2019 7:18:35 GMT -8
brian1313
Post by brian1313 on May 14, 2019 6:16:18 GMT -8
thanks mobiltec
