Post by nccamper on Jan 22, 2019 19:27:53 GMT -8
Hi Friends, is it optimum to screw this piece of steel into the cross member before you mount the cross member into the framework? Yes. Before is much easier.
I reused the same metal support piece on most camper.
Windborn, I built a shelf under the Compact rear window. It makes great storage, supports the wall and covers a water stain. It matched the shelf above the window. Our Forester front window has a ledge/shelf we use a lot.
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jan 26, 2019 9:33:33 GMT -8
Can you show me a close up of your COmpact shelf ?- I want to do that, but dont know how to go about it. THanks
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jan 26, 2019 14:40:36 GMT -8
Well- I worked on that frame piece today- and she is in! Also installed the interior wooden piece that holds the table brackets. Thanks to you all for the help- I so appreciate it! Would not have known to install the metal if I didn't ask! K IMG_5820 by kathy, on Flickr IMG_5821 by kathy, on Flickr IMG_5819 by kathy, on Flickr I need to remake the longer piece for the interior just below the window- That's tomorrows job:)
Post by nccamper on Jan 26, 2019 16:28:33 GMT -8
Can you show me a close up of your COmpact shelf ?- I want to do that, but dont know how to go about it. THanks I don't have a close up. These are as detailed as I have. It's 1by bottom and sides, left over birch for the face which matches the scalloped shelf above.
