PT
Post by PT on Aug 4, 2019 15:23:20 GMT -8
PT
Post by PT on Aug 14, 2019 20:23:38 GMT -8
I'm a happy boy - first ceiling panel went in a couple days ago. It's the one in the center of the trailer. I'm pretty sure the roof/ceiling on the Holiday House was built separately and lowered onto the top of the walls from above. Everything is made of solid lumber - no laminating like a canned ham. The rafters are very tightly finger jointed into the roof side rails and both the side rails and the top wall frames are continuous pieces of wood 15ish feet long. Luckily the ceiling framing can be reused and I'm able to piece it back together in sections. There is a small flickering light at the end of the tunnel :-)
Post by mobiltec on Aug 16, 2019 13:20:07 GMT -8
You're doing a very nice job Bryan. When I saw the pin hole in the aluminum water tank I was going to tell you to just discard the thing. Once you see one pinhole on the outside you know that others will occur soon after the tank is pressurized. I tried to fix a pin hole in the same tank once, pressurized the tank and another one appeared. Then another and another so I gave up and put a new poly tank in from Vintage Trailer Supply.. And while I was at it I doubled the size of the tank being that I had the room.
PT
Post by PT on Aug 17, 2019 17:36:17 GMT -8
Thanks Larry -
I'm guessing Bryan must be my deep cover CIA alias or something - not quite sure where Rod came up with it :-).
My real name is Allan and I agree about the aluminum tank. I thought about trying to patch the pinholes but kept picturing new ones popping up so the newfangled plastic one will be ordered soon!
Post by mobiltec on Aug 17, 2019 20:00:28 GMT -8
Got it Allan.
PT
Post by PT on Aug 20, 2019 18:14:19 GMT -8
debranch
Wee Camp
71 Shasta Compact
Post by debranch on Aug 20, 2019 18:55:07 GMT -8
I love the color combo. Debra
Post by Hamlet on Aug 20, 2019 20:02:20 GMT -8
I love the color combo. Debra The fabric is (to use a sixties word) fab, and the Marmoleum and countertop will look just wonderful with it.
Post by mobiltec on Aug 21, 2019 5:40:12 GMT -8
I've got a Micrometer just like that. Think I got it on either Amazon or at Harbor Freight... Can't remember which.
PT
Post by PT on Aug 21, 2019 15:19:15 GMT -8
$19.99 on Amazon... Probably reverse engineered in China from the German version that's $150.
aries
Post by aries on Aug 22, 2019 9:12:06 GMT -8
Nice progress on the trlr pt,really like the retro look fabric you've picked.in surfing a trlr site came across an Aloha holiday knockoff,huum. Mark
PT
Post by PT on Aug 25, 2019 16:38:24 GMT -8
Post by vikx on Aug 25, 2019 22:06:09 GMT -8
Snide remark: they pry quit making the knock offs because those windows leaked like sieves.
Thanks for the photos, PT.
PT
Post by PT on Aug 26, 2019 11:28:47 GMT -8
My thoughts exactly - they are guaranteed leakers... but they look cool while they're leaking :-)
Horizontal ledges and other sketchy areas next to the window frame/putty meeting point are a bad idea. I'm going to try to create some slope so water might run away from the windows when it's sitting still and will be using lots of putty tape!
Post by mobiltec on Aug 26, 2019 17:22:43 GMT -8
My thoughts exactly - they are guaranteed leakers... but they look cool while they're leaking :-) Horizontal ledges and other sketchy areas next to the window frame/putty meeting point are a bad idea. I'm going to try to create some slope so water might run away from the windows when it's sitting still and will be using lots of putty tape! Just keep it dry.
