PT
Post by PT on May 7, 2021 12:17:24 GMT -8
BINGO!
Yep - I'll likely try to match the fridge door to the yellow Wilson Art Cracked Ice counters. Unfortunately I don't have enough of their Formica left and don't know if I want to shell out another $140 for a 4x8 sheet... There is some good looking very durable contact paper that I might cover the wood insert with that would be a close match.
WhitneyK
'67 Shasta Compact
Post by WhitneyK on May 7, 2021 15:00:18 GMT -8
BINGO! Yep - I'll likely try to match the fridge door to the yellow Wilson Art Cracked Ice counters. Unfortunately I don't have enough of their Formica left and don't know if I want to shell out another $140 for a 4x8 sheet... How big of a piece do you need? (dimensions)
oldman
Post by oldman on May 7, 2021 15:52:26 GMT -8
PT- Another option for your door fridge could be car wrap material or any piece of vinyl. Lots of color options out there to try and match a yellow. Check out Amazon or locally at place like Fast Signs.
Also, do people still drink beer out of glass bottles? Glass is not even recyclable where I live. And for camping it takes up more space and is heavier.
PT
Post by PT on May 7, 2021 16:02:31 GMT -8
Oooooooh - the manual says 25 and 15/16ths by 20 and 1/8
PT
Post by PT on May 7, 2021 16:23:34 GMT -8
PT- Another option for your door fridge could be car wrap material or any piece of vinyl. Lots of color options out there to try and match a yellow. Check out Amazon or locally at place like Fast Signs. Also, do people still drink beer out of glass bottles? Glass is not even recyclable where I live. And for camping it takes up more space and is heavier. Thanks - I'll check out the vinyl option! Personally - I have never met a beer or beer receptacle I didn't like ;-) and thankfully Oregon does recycle beer and soda bottles as part of its "Bottle Bill" recycling program.
Post by mobiltec on May 14, 2021 14:34:59 GMT -8
PT- Another option for your door fridge could be car wrap material or any piece of vinyl. Lots of color options out there to try and match a yellow. Check out Amazon or locally at place like Fast Signs. Also, do people still drink beer out of glass bottles? Glass is not even recyclable where I live. And for camping it takes up more space and is heavier. I still drink two different kinds of beer from glass bottles. It just tastes so much better that way. I am usually able to find places to discard my glass and trash legally. If not I pack it home.
pthib
1966 Buco
Post by pthib on May 23, 2021 6:30:47 GMT -8
PT, another option to cover the fridge door is a vintage style travel poster. I found a reprint of a 1922 CP rail poster advertising Holidays in Canada and installed into the fridge door on my 1966 Buco. It was almost the exact size I needed. I slid it into the door channel and covered it with a 1/16 thick plexiglass panel. I posted a picture on this forum, just search buco and you can find it.
PT
Post by PT on May 25, 2021 18:37:49 GMT -8
Thanks - cool idea - I've been considering some similar creative ideas. Spoonflower.com prints some cool Tiki and Atomic themed contact paper/wall paper that I've been thinking about too. Now I can look for the perfect travel poster as well :-)
PT
Post by PT on May 27, 2021 9:15:24 GMT -8
PT
Post by PT on Jun 6, 2021 23:00:51 GMT -8
Post by nccamper on Jun 7, 2021 3:05:20 GMT -8
Looks great. Where did you get the axle and how much did it cost?
PT
Post by PT on Jun 7, 2021 7:31:37 GMT -8
It's a Dexter axle - 4 inch drop - 77" hub face to hub face - got it here: sixrobblees.com$290
Post by mobiltec on Jun 10, 2021 11:34:36 GMT -8
It's a Dexter axle - 4 inch drop - 77" hub face to hub face - got it here: sixrobblees.com$290 Good price.
Post by nccamper on Jun 11, 2021 4:37:35 GMT -8
It's a Dexter axle - 4 inch drop - 77" hub face to hub face - got it here: sixrobblees.com$290 Thanks. How much did the full set up cost? It's valuable info for our members. Often a needed repair that goes undone.
WhitneyK
'67 Shasta Compact
Post by WhitneyK on Jun 13, 2021 8:12:36 GMT -8
Today was a painting day for the Holiday House. I learned a nice trick via a You Tube search for painting rims while the tires are still on them. Deflate the tires and overlap 3x5 index cards under the lip of the rim all the way around. I cut a 17" circle in painters paper to mask the rest of the tire - worked perfectly :-)
Not trying to derail you thread, just wanted to share. I found a way to break down the bead on a tire to help with painting without having to go to the tire shop. I hooked up a utility trailer to my truck and used the tongue jack to push the bead down thus popping it loose from the rim. Be sure to put the jack foot close to the bead. I really like your idea too!
