Post by justinrieff on May 30, 2018 12:31:23 GMT -8
Post by vikx on May 30, 2018 20:34:55 GMT -8
Welcome Justinrieff, it's really a pretty little trailer! I've not heard of Skylarks.
Most leaks are caused by bad putty, especially at the J rails (edge trim). Trailers with past leaks often have some pretty nasty rot at the bottom. I suggest you loosen the skins and take a look.
Also, check the air conditioner seal. If you take the inside plenum off, you will see four bolts. If there's no daylight showing, you might be able to snug the A/C and reset the seal. (It's a rubber thing)
Anytime you see caulk or slop on the roof is a time to be suspicious. People don't try to goop their trailers unless they are leaking.
We are here to help. Look around and check out some of Mobiltec's Youtube videos.
skylark
Post by skylark on Jul 15, 2019 18:23:47 GMT -8
I have 2 Skylark campers. A 1958 13 ft. canned ham and a 16 ft. 1972 travel trailer.I have not been able to find info or even many photos of vintage Skylark campers. I hope we get some response from the forum folks.
I have seen a few photos on a google photo search for vintage campers that were titled Skylark, Shasta. I also have asked the forum for info as to the possibility that they were made by Shasta and offered as a lower cost alternative to the Shasta brand.
There have been campers made in the last 20 years or so that were sold under the Skylark name.
