man314
1964 Shasta 16-SC
Post by man314 on Apr 28, 2018 9:45:46 GMT -8
Putting last touches on wiring. Insulation in place. Vapor barrier close to going on and new Hemmet Valley skins waiting patiently in the garage. I had assumed we would be camping with the cool old nostalgic fan I bought her at Christmas. My wife says “what about AC?” Well, glad she weighed in before I got skin on! Ive read most of the posts here. I like the idea of a portable cause I will only need it in worst of summer. I was looking to fit one in the closet of my 64 Shasta SC. I will not put one in a window or run hoses to a window. Don’t want to exhaust the heat into the trailer . . . Kinda defeats the purpose, but Ive seem people do just that. I did read where someone found a unit they set outside and ran a flex hose through luggage compartment under Goucho. Sweet idea! Some of those posts were several years back. Anyone do this? How did it work? Anyone use one a two way units that heat and cool? Anyone use an industrial spot cooler? Seems like it would make it easy to adapt to the end of the hose to a vent inside. Recommendations? Any advice is appreciated
Industrial Spot Cooler
shastatom
Shasta 54,57 1500 58 Airflyte
Post by shastatom on Apr 29, 2018 4:42:39 GMT -8
I will be interested to follow what you do. When I did the rebuild I left a spot under the stove, oven to put a AC unit but that meant I would have to vent the wall and vent through the floor. I have followed this one a bit hoping that maybe this would be a good solution. www.youtube.com/watch?v=4-A4zJuROWY
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Aug 16, 2018 17:32:30 GMT -8
Following- would love to hear others ideas for a/c.
oakback
Post by oakback on Aug 17, 2018 5:33:28 GMT -8
I plan on doing a window unit on drawer slides with a access/storage door on the exterior. Slide in when moving, slide out when parked. How it mounts to the slide would determine how easily/quickly it could be removed. Whether is simply strapped to a wooden shelf (which is then screwed to drawer slides), or if the a/c housing is screwed directly to the slides. But either way, it's removable and replaceable without any modification to the exterior siding or camper structure. The access door stays in place regardless.
aslmx
Post by aslmx on Aug 18, 2018 18:17:36 GMT -8
man314
1964 Shasta 16-SC
Post by man314 on Mar 1, 2019 13:53:49 GMT -8
Yeah, life happens and I got delayed a bit. Grandkids. Boating. Trips overseas, etc. My wiring is done, but I’m still considering using an external unit. Found a small spot cooler that I thought I’d carry in the truck and take with us only when we needed it. I ran heavy gauge romex to an weatherproof external plug just to the right of the baggage door under the frame. Thought is that I could have unit locked up outside (pulling in fresh air, and expelling the hot air). Hook cooling duct to a duct I would build under the goucho. 6130 BTU Spot Cooler
I can find it cheaper on Amazon, but the link won’t work.
Post by nccamper on Mar 2, 2019 2:08:56 GMT -8
It's 51 pounds which is hard to handle. The video seems to be saying it's only an inside unit.
With that said, I like it.
n2hcky
1967 Serro Scotty Hilander
Post by n2hcky on Mar 2, 2019 5:47:15 GMT -8
I do not know how well these work. I have seen good and bad reviews. Not sure how it would work for your set up but it is an option. Climateright
Post by nccamper on Mar 2, 2019 7:07:46 GMT -8
I do not know how well these work. I have seen good and bad reviews. Not sure how it would work for your set up but it is an option. ClimaterightAn interest option. 63 pounds is a lot of weight.
Post by ladywendolyn on Mar 3, 2019 6:38:14 GMT -8
This link has about a dozen different solutions by different Scotty trailer owners. Great resource. I am personally installing my unit under a bench and putting a snout on the front and ducting inside the closet to have it vented up at the ceiling. I paid $99.00 for my unit from Walmart. I am undecided yet on whether it will slide out on a tray or have a baffle and then a drip tray. My main goal is that it is not visible ... nationalserroscotty.org/resources/ac.html
aslmx
Post by aslmx on Mar 14, 2019 18:49:06 GMT -8
shekaye
crazy
Shasta Trailer - unknown
Post by shekaye on Nov 19, 2019 5:41:40 GMT -8
This link has about a dozen different solutions by different Scotty trailer owners. Great resource. I am personally installing my unit under a bench and putting a snout on the front and ducting inside the closet to have it vented up at the ceiling. I paid $99.00 for my unit from Walmart. I am undecided yet on whether it will slide out on a tray or have a baffle and then a drip tray. My main goal is that it is not visible ... nationalserroscotty.org/resources/ac.htmlHas anyone put a roof mount Dometic heatpump airconditioner? If not, why?
kathleenc
Post by kathleenc on Nov 19, 2019 7:29:21 GMT -8
I would caution you that some of the heat pumps shut off when the temp drops below 40. It's a very unpleasant surprise if this happens at night and you're out in the middle of nowhere. This happened in our big Spartan on the ranch and it's probably the coldest I've ever been - too cold to even sleep. It had been above 90 earlier in the day and we had used the a/c so we were caught completely off guard. And of course, most of our small trailers could not handle that much weight on the roof.
Post by mobiltec on Dec 13, 2019 14:30:08 GMT -8
This link has about a dozen different solutions by different Scotty trailer owners. Great resource. I am personally installing my unit under a bench and putting a snout on the front and ducting inside the closet to have it vented up at the ceiling. I paid $99.00 for my unit from Walmart. I am undecided yet on whether it will slide out on a tray or have a baffle and then a drip tray. My main goal is that it is not visible ... nationalserroscotty.org/resources/ac.htmlHas anyone put a roof mount Dometic heatpump airconditioner? If not, why? WAYYYY too heavy for the roof of that trailer and even if you beef up the roof you must still beef up the walls and add gussets and stuff. Not worth it. Other ways to cool the trailer.
