man314
1964 Shasta 16-SC
Post by man314 on Apr 26, 2018 5:24:51 GMT -8
I’m completely reskining by 64 Shasta SC. New metal has auto edge on bottom. What are people using to trim out wheel well openings? I’ve seen door edge guards, but most of them are rubber. I’m assuming there is a flexible, bendable, paintable material that can be attached without bulky screws?
Post by Ross on Apr 27, 2018 2:55:16 GMT -8
In most cases, you would use the same J trim that is used on the 2 outer edges for the wheel well cut outs.
Post by vikx on Apr 27, 2018 20:38:33 GMT -8
Try to find malleable aluminum J rail as well. Some is more 'bendy' than others...
191ronnie
1958 Mercury
Post by 191ronnie on Sept 22, 2018 14:00:58 GMT -8
I'm at the same point in my trailer so I appreciate this thread. Does the jail rail get attached to the underside of the wheel well? Is the rounded part toward the outside? Do you have a picture of it installed? I've looked and not seen a close up picture. Thanks!
Post by vikx on Sept 22, 2018 21:21:38 GMT -8
Yes, the rounded part is to the outside which holds the skin at the wheel well. Wheel trim is not puttied but is allowed to drip and breathe. Almost all of the pictures here of a whole trailer will show the wheel well trim.
191ronnie
1958 Mercury
Post by 191ronnie on Sept 24, 2018 7:05:45 GMT -8
Thanks-I appreciate the replies. Now I understand how the j-rail is bent around. I hadn't found a close-up picture of the wheel wells and couldn't tell from the other pictures how it was done. I traced the outline of my wheel well on some 1/4" plywood then did the same with some 2x4 "chunks". I cut them with the band saw and attached them to the plywood so I could bend the j-rail around it. As I bent the j-rail around the curve I screwed it down with #6 screws so it wouldn't twist. I'll cut it to the proper length today, paint and install it. Thanks for the info!
HOTRODPRIMER
1957 Shasta
Post by HOTRODPRIMER on Oct 31, 2018 18:04:57 GMT -8
In the future you can take your original pieces to a automotive restoration shop or a tech school that teaches automotive body work and they usually have a tool called a Shrinker Stretcher and they can take a straight piece of metal and make it contour to the shape of the wheel well opening.
I have use one of these many times. Danny
191ronnie
1958 Mercury
Post by 191ronnie on Nov 2, 2018 11:48:36 GMT -8
Thanks for the input!
Post by 60cannedham on May 31, 2019 14:09:19 GMT -8
This is our problem as well. Nothing seems to have worked that we came up with thus far. Thank you for this thread.
Alaska Shasta
1964 Shasta
Post by Alaska Shasta on May 31, 2019 14:59:19 GMT -8
Post by 60cannedham on May 31, 2019 15:06:59 GMT -8
Awesome, thank you!!!
n2hcky
1967 Serro Scotty Hilander
Post by n2hcky on Jun 2, 2019 4:33:43 GMT -8
The corner edge trim for the Scotty formed well even on the extreme bend of the swoop cut out. 20190421_172011 by
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Oct 20, 2019 10:58:58 GMT -8
The corner edge trim for the Scotty formed well even on the extreme bend of the swoop cut out. 172011 by Where did you get this moulding? THanks
debranch
Wee Camp
71 Shasta Compact
Post by debranch on Oct 20, 2019 16:55:44 GMT -8
Post by danrhodes on Oct 20, 2019 17:00:35 GMT -8
Mine just use j-rail for the wheel wells.
