Post by kirkadie on Nov 16, 2013 13:35:22 GMT -8
Aloha, I'm sure you're already aware of the precautions needed for cleaning up after our little guests but in case you or someone else is about to take on the chore, please read this first... www.cdc.gov/hantavirus/hps/transmission.htmlI'd sure hate to be saying "aloha" to anyone of the gang if they got HPS jst because they didn't know how nasty it can be.
Aloha!
1964 Shasta 1500
Post by Aloha! on Nov 19, 2013 5:28:32 GMT -8
Thanks Kirkadie. Until this article I had been under the impression that it was the city slicker rodents you worried about and NOT the rural rodents. Turns out to be the exact opposite. Shows how much I know... or didn't know. Not looking forward to this job at all. Thanks again.
Post by kirkadie on Nov 19, 2013 18:29:39 GMT -8
Aloha, think of it like cleaning a great big cat litter box while wearing a paper suit (or just long sleeves and socks and gloves) and respirator... not a big deal if you suit up properly. Besides some safety gear, I just used a shop vac which I dumped out behind the garage in my leaf and grass clipping pile. I shot the floor with some clorox clean-up because I thought I might want to save the linoleum (I didn't). Once the worst of it was gone, as I tore the trailer down to replace the rotten wood, the errent few missed mouse droppings just went in the garbage with the tear out debris... I wore my usual painting respirator, which is a big box home improvement store $35 dual cartridge nose and mouth mask that you should have when you spray your shellac and outside paint if you go that far. Don't be worried, just properly equipped, which you'll want to be for any of the upcoming tasks. No different than wearing goggles when you're using the dremel tool to cut slots in all those rusty screws in the J rails. That said, my dear friend Scott Estes got the disease from mouse droppings in the insulation in his attic, suffered for many years, and finally succomed to it's after effects, so simple precautions are warranted.
Aloha!
1964 Shasta 1500
Post by Aloha! on Nov 20, 2013 4:59:52 GMT -8
Originally I was just going to don some work gloves and a bucket. Now I'll buy the surgical masks, rubber gloves and a big bottle of Clorox and a spray bottle. It'll all still go in the bucket. I, too, was going to dump the bleached nests/debris out in my woods. Now, probably into a compactor lined bucket to be sealed and taken to the dump. Better safe than sorry. And I'll be checking out a painting respirator this week.
Sorry to hear of your friend Scott. That's terribly sad.
Post by mobiltec on Nov 20, 2013 18:31:04 GMT -8
I've done a fair amount of mold remediation work in homes and you don't want to use a "spray" anything in the normal manner. Don't spray any surface or pile of stuff directly. Spray above it and let the mist fall down on the affected area. If you aim the sprayer at it you will blow all the mold spores into the air along with the mouse poop dust and that's how both diseases become airborne.
Aloha!
1964 Shasta 1500
Post by Aloha! on Nov 21, 2013 3:57:04 GMT -8
Excellent point. Thank you. My resulting question though is if I'm supposed to saturate it, believe I read that, isn't it hard to do if I just mist from above?
Post by mobiltec on Nov 21, 2013 8:17:16 GMT -8
Not at all. Try it and you will see how it works. Just don't blast away straight at the stuff until it's damp.
Aloha!
1964 Shasta 1500
Post by Aloha! on Nov 21, 2013 10:16:36 GMT -8
Okie dokie... Done. Well, done in the sense that I'll do as you recommend not as in completed task. That may or may not be this weekend after all. The high temp in the valley is expected to be 29*. Take 5* off for every 1000' in elevation and that makes....... about 19*. And then you have the high winds coming in with it. Hummmm...... maybe it'll be "done" this weekend. Thatnks for the advice.
