otfiddler
We're from Texas --- what country are YOU from?
'67 Shasta Compact
Post by otfiddler on Feb 10, 2018 13:18:21 GMT -8
I just saw a video on a wind generator that is very interesting, a style that I would build for myself (if I had any gumption), and I wonder if anyone here has knowledge of and/or experience with this one: Video here: www.youtube.com/watch?v=CY-Th0WVpDQVendor's URL: www.alekoproducts.com/Magnet-Vertical-AC-Wind-Generator-400W-12V-p/wgvq400w12v-ap.htmI don't trust the specs on output-to-windspeed that the guy in the video throws out, and I've request a graph or table from the company, showing wattage output for the full range of windspeeds. I also requested info on how much noise it makes, but I can't imagine it would be very noisy. I've always been a fan of vertical axis wind generators, and this one looks pretty promising! Larry
Post by vikx on Feb 10, 2018 21:22:05 GMT -8
I wish I knew more, it does sound interesting!
Post by nccamper on Feb 11, 2018 6:18:47 GMT -8
A good idea for a park model camper. But 6-16mph steady wind is hard to come by in NC.
My wife loves green ideas. Thanks for sharing.
gary350
1964 FAN
Post by gary350 on Mar 4, 2019 11:26:50 GMT -8
Wind mills work best in a steady wind. I live in TN wind is very gusty here. I use to fly kites when I lived in AZ wind is very steady continuous stream all the time there. Wind it too gusty to fly a kite in TN one minute wind is 10 mph for 30 seconds then dead calm for 20 seconds then 5 mph for 25 seconds, wind is up and down random speeds all day. In TN gusty wind for a wind mill will give you an average 0 to 15 mph might average out to about 7 mph. Those old wind mills farmers use to have to pump water will turn in a 2 mph wind and good up to about 20. Each type wind mill works best at certain wind speeds. Make sure you know your wind conditions then buy a wind mill to match it. I have a 40 years book that shows how much power a certain will mill blade produces this same information is probably online. Build a few small yard wind mills to test different designs. Every time wind mill diameter doubles the power triples. 4' dia produces 3 times more power than 2' dia. 8' is 3 times more than 4'. I don't remember math formulas to calculate power it will be online. Do google search for windmill calculator.
