Deleted
Post by Deleted on Jan 22, 2018 14:46:28 GMT -8
Hi Nate,
I believe the rear bumper is stock to this Detroiter. The photos below show the cavity in the square tube that houses the waste tube for dumping. Since I have a bathroom, I would expect this to be original to the trailer. The hinged end plate is broken off, but the owner gave me that piece to weld it back on during my build. My FAN also has a bathroom and has this same "tube in the bumper" feature.
I took a bunch of photos yesterday and will post a more thorough update to this thread later this evening.
Deleted
Post by Deleted on Jan 23, 2018 12:57:32 GMT -8
Post by Teachndad on Jan 23, 2018 17:04:52 GMT -8
Hi Friends, I really always enjoy looking at pix of trailers all lined up like bw has in the top photos. Something about that really looks cool. Makes for a collection. I agree the back bumper has gotta be stock. It's in the ad for the trailer, which is a really nice lucky find. If we could all be so lucky. Cheers, Rod
Deleted
Post by Deleted on Jan 23, 2018 17:17:46 GMT -8
Thanks Rod...I really appreciate your feedback. Of course I'd like to add to the collection as I have plenty of space. Just need to convince DLW...
Deleted
Post by Deleted on Jan 23, 2018 20:34:42 GMT -8
To continue on with part 2 photos and narrative...
This water fill was likely modified with a spigot for direct hose connection. Note there is also an air valve to pressurize the internal steel tank.
I may swap the above out for this system that is on the Real-Lite truck camper I'm parting out. I'll clean up or replace the pressure gage.
The owner had removed the trap under the sink and replaced it with a drain out the side of the trailer. This to prevent water from freezing and damaging the internal plumbing. The trailer was used for ice fishing during the past (20) odd years and stored during the summers. I'll plan to remove the tube and patch the siding.
The waste plumbing below hasn't been used in years as the owner replaced the toilet with a bucket and lid.
I'll plan to install this working toilet from the Real-Lite and make the bathroom operational again.
The waste tube stored in the rear bumper. I have the broken off end plate to weld back on.
The exterior vent grille for the refrigerator is in good shape. The refrigerator itself is gone, however. Notice the antenna mount adjacent to the grille. I believe this is original as I have the same installed on my FAN.
I may install this refrigerator from the Real-Lite assuming it works OK. The pink will go really well with the interior.
Not sure what this is adjacent to the door?? Some sort of mount for a catch?
This appears to be a bumper for the door?
The roof looks good. The owner applied sealer to the surface when he acquired this trailer in 2006. It hasn't been touched since.
There are (4) square cutouts underneath for ice fishing. The remaining underside is a coated fiberboard that looks really good. I'll patch in or replace complete with a similar material.
The Bargman door handles are a bit pitted but work fine. I have (2) original keys as well. I'd like to clean these up and possibly replate?
The screen door is missing, so I'll need to find a replacement.
So there's the exterior. I'll continue on with interior photos and narrative next...
Post by vikx on Jan 23, 2018 22:48:42 GMT -8
It's got a lot of potential. Run the sink drain thru the floor, no trap. Works for me.
I think with sanding and inspection, the roof might be savable, depends on what the coating is. I have sanded and clean the peeling debris off, then sealed anything that looked suspicious. Paint really makes the whole thing look good again. Be sure to inspect for pinholes before repairs.
Deleted
Post by Deleted on Jan 23, 2018 23:34:12 GMT -8
I'll have to take a close look at the plumbing system when I get to that point. I'm assuming the trap was necessary as the grey water drained into the same tank as the black water? I would have to separate the waste systems to avoid use of the trap, but that may be easily done and preferable. Not sure yet...
I'm happy to see the roof in this condition and expect to keep it original with no problem. As you suggest, I'll remove the coating residue, bring it back to the base metal, inspect for any pinholes, and recoat to seal and improve the appearance.
Post by vikx on Jan 24, 2018 21:03:22 GMT -8
If it has pinholes, nothing will work. Roof cancer is insidious and you can't possibly seal enough to cure it. If there is damage, (like dents or holes) if they are not too bad, you can sticky tape the underside and then coat just before paint. ONLY in iffy areas not the whole roof.
This isn't the one with the steel roof is it?
Deleted
Post by Deleted on Jan 24, 2018 21:54:04 GMT -8
Continuing with part 3 interior photos and narrative:
A previous owner reworked the left hand side of the trailer as viewed from this direction. The upper cabinet is pushed back - you can see the faint outline on the ceiling from where it belonged originally. It appears this was done to accommodate the addition of the table below. In the following photo you will see the original table at the front of the trailer missing in lieu of a bed. My guess is that a table was located central to the fish house so the fellows could play cards, drink beer, and keep an eye on the (4) corner ice fishing holes all at the same time.
From this view you can see the missing table replaced by a bed.
Another view of the left side. The refrigerator is missing as the table butts up directly to the wall here. Note the furnace turned 90 degrees and the upper vent ductwork altered. The closet that houses the furnace adjacent to the upper cabinets and refrigerator was removed. I'll plan to reposition the furnace and upper cabinet to original, rebuild the closet/wardrobe, and install a refrigerator. Hopefully I can match the woodwork properly.
A couple photos of the opposing wall.
Love the pink stove and sink - will match the exterior painted stripe perfectly.
The bathroom looks good with base intact. A working toilet will be installed.
The end walls transitioning through the ceiling look great.
The vent is in perfect shape with no sign of water intrusion.
This original tile flooring will likely be found under the carpet throughout.
The water tank looks to be in good shape.
The square hole cut in each of the (4) corners.
A final parting shot of a rattle reel used for ice fishing. When the fish takes the bait and line, the reel has a few internal beads that make an audible "rattle" when spinning. This alerts the fellow that is usually sleeping by now of "fish on!"
There you have it. A 16 1/2 foot Detroiter Traveler. Can't wait to get started!
Deleted
Post by Deleted on Jan 24, 2018 22:00:35 GMT -8
If it has pinholes, nothing will work. Roof cancer is insidious and you can't possibly seal enough to cure it. If there is damage, (like dents or holes) if they are not too bad, you can sticky tape the underside and then coat just before paint. ONLY in iffy areas not the whole roof. This isn't the one with the steel roof is it? The Catalina and DLW's Maple Leaf have steel roofs. This Detroiter is made of aluminum. I expect it will be fine as there is just no sign of rot above the internal ceiling anywhere. I'll know for sure when I peak under the skins.
Post by vikx on Jan 24, 2018 22:47:16 GMT -8
Ah, thanks.
