62ham
62 Oasis
Post by 62ham on Jan 16, 2018 9:38:29 GMT -8
Post by vikx on Jan 16, 2018 20:41:22 GMT -8
I don't think it will work in a trailer. It requires a wall at a minimum of 4 1/2" thickness. Not sure if that's because of the vent or not. It's 8K BTU which is a LOT in a small trailer. I would contact the manufacturer and find out why they want that thick of a wall?
Also, it weighs 50 pounds which is heavy in a ham. Be interesting to do some research.
Post by bigbill on Jan 17, 2018 4:59:47 GMT -8
My guess is that since most buildings are at least 2x4 construction that is why it is designed with a 4 1/2" minimum wall.
Post by turbodaddy on Jan 17, 2018 19:00:51 GMT -8
Windows fogging up is just a minor inconvenience. We've experienced times when blankets next to an outside wall actually get wet from condensation. This is with a vented Attwood furnace. Just our breath and cooking moisture is enough to cause a problem in really cold weather. We keep a couple of windows cracked, but still have problems. Usually it is the aluminum window frames that cause the most condensation. Wet bedding really sucks and is really hard to remedy in the boonies.
Deleted
Post by Deleted on Mar 6, 2018 20:06:35 GMT -8
I agree with bigbill.
