Poquito
Post by Poquito on Jan 6, 2018 17:15:22 GMT -8
Getting ready to order a drop in sink and noticed the drain hole is 2 1/8 diameter. I am doing a simple handle pump faucet and will have jerry cans clean and grey water set-up underneath, no line to a tank under the bed like the original. Has anyone done this with a sink hole of this size and how was it done? If this creates too much piping underneath or complicated what should I be looking for in the way of a sink.
Thanks!
Post by vikx on Jan 6, 2018 21:45:12 GMT -8
If you are ordering a sink, there should be a drain to fit it. I use a hose thru the bottom of the trailer for the drain; it goes into a bucket or tote. Connect the drain, screw an adapter on and reduce to 1" or 3/4", your preference. Use a barb to attach the hose. I use 3/4 tractor 'breather' hose-it's softer and lasts a long time. The other option is to shorten the hose and go into the grey tank. PM me for photos or look here: s189.photobucket.com/user/vikxphotos/library/Displays%20Parts%20and%20Pieces/Plumbing?sort=6&page=2&hotlinkfix=1515303800801There's several different sink drains for you to see. Scroll thru the pages.
Post by Ten on Jan 7, 2018 0:22:58 GMT -8
I think the two inch size is common for smaller sinks Look for a strainer and plug for a bar sink. You should be able to find one at any big-box or plumbing supply, or online if that's your poison... After the strainer, everything else is standard sizes, so adapting to your desired setup is much easier.
62ham
62 Oasis
Post by 62ham on Jan 16, 2018 13:52:40 GMT -8
