dutchy
Post by dutchy on Oct 22, 2017 12:38:54 GMT -8
Hello- I need help in identifying this camper trailer. I was told it was a 1970 and at first I thought it might be something similar to a HI-Low. It raises the first level by a single hydraulic ram and cables and then the second level raises by 4 independent hydraulic rams like a slide in Alaskan camper. The top section would then have canvas sides like a slide in pop-up camper. bit was removed by the old owner due to cracking. Most of the amenities were Coleman Holiday branded items like the range/stove and fridge. No other identifying information on the trailer. I've searched everywhere but cannot find another like it. Any help in identifying it would be greatly appreciated. IMG_0837 by Jayde Van Cleave, on Flickr IMG_0830 by Jayde Van Cleave, on Flickr IMG_0831 by Jayde Van Cleave, on Flickr IMG_0833 by Jayde Van Cleave, on Flickr IMG_0835 by Jayde Van Cleave, on Flickr IMG_0834 by Jayde Van Cleave, on Flickr IMG_0840 by Jayde Van Cleave, on Flickr IMG_0838 by Jayde Van Cleave, on Flickr
tiny
Post by tiny on Oct 26, 2017 22:03:13 GMT -8
Well... That IS a stunner. I don't know what it is either! Looks like the inside Is in pretty good shape. Check the title If you have it. I hope someone can id it. Good luck.
Post by mrmarty51 on Oct 27, 2017 13:22:47 GMT -8
It could even be a home built.
Post by countessjaye on Dec 3, 2017 16:56:03 GMT -8
Maybe a conglomerate? Because looking at the rear wall, dinette, it is almost identical to my 1972 Jet. Same table and brackets, pole and such. Same bold print with vinyl sides on the cushions, same window and fiberglass panel. However nothing else about it is like mine. What do you think the telescoping top is for?
Post by Ten on Dec 3, 2017 21:38:45 GMT -8
My first guess was a Hi-Lo. I don't believe I have ever seen anything like this one. Definitely a few early-70's features.... Where's vintagebruce ??
Post by mobiltec on Dec 8, 2017 14:38:59 GMT -8
Weirdest dang thing I've ever seen but I like it. Huge top vent LOL...
