smac75
Post by smac75 on Oct 16, 2017 7:24:37 GMT -8
Hi,
I replaced 11" of flooring at the rear of my trailer. The new piece meets the old piece inside of storage compartment so doesn't need to be pretty. Metal flashing? A long piece of wood that sits on top of the seam? Glue?
Thanks!
Post by vikx on Oct 16, 2017 19:40:14 GMT -8
Can you get to the underside? My Shastas have had a piece of ply at the seam, but under the floor, not on top. Also, you'll need floor joists at the seams to support the new piece.
smac75
Post by smac75 on Oct 17, 2017 6:57:54 GMT -8
Can you get to the underside? My Shastas have had a piece of ply at the seam, but under the floor, not on top. Also, you'll need floor joists at the seams to support the new piece. Hi Vikx, yes, I can get to the underside and yes, the seam is on a joist. Are you recommending I bolt a piece of new plywood on the underside to cover the seam?
Post by vikx on Oct 17, 2017 19:10:07 GMT -8
If the seam is on the joist, attach the plywood to the joist. The seam shouldn't be exposed if it's on a joist?? If you want to seal it, caulk the joint.
smac75
Post by smac75 on Oct 18, 2017 6:27:18 GMT -8
Sorry, maybe my terminology is off. The new piece sits on top of a piece of wood that's attached to my metal frame (the wood is up against and runs in parallel with one of my metal frame members - that's a joist right?) so the seam is only exposed on the top/inside of the trailer. It's not exposed underneath.
Post by vikx on Oct 18, 2017 19:44:35 GMT -8
You can use floor leveler inside on the seam, then sand flush. Be sure the ply is securely attached to the joist.
