silvertonguedevil
1958 Shasta ~ 1959 Windsor
Post by silvertonguedevil on Oct 7, 2017 16:04:26 GMT -8
My trailer didn't come with any keys so I'm wanting to replace the locks on both baggage doors. However, I'm being thrown for a loop. I can't seem to get anything apart even with the two screws removed. I thought I'd check here to see what I'm missing. Any help is greatly appreciated!
silvertonguedevil
Post by silvertonguedevil on Oct 7, 2017 16:24:17 GMT -8
Post by Ten on Oct 7, 2017 18:46:41 GMT -8
Is it possible that the collar around the lock cylinder is supposed to unscrew from around it? Just a WAG....
Post by vikx on Oct 7, 2017 20:44:13 GMT -8
Try PB Blaster penetrating catalyst (not regular lubricant). Ace carries these locks (or did) You should be able to find a matching lock online or look at one to figure it out...
silvertonguedevil
Post by silvertonguedevil on Oct 7, 2017 21:08:03 GMT -8
Alright, I figured it out. After asking my wife to read the small stamped letters on the back of the lock, I was able to hop on Google and see a lock by itself. It was then obvious to me that it was being held in by an extremely tight fit and it just drove straight out the back side. I was able to do that with a rubber mallet. Thank you for your help!
